Thinking Wakie Nov 1 maybe... Depends if i can get the front tyres sorted before then and i also have to measure my brakes...
Mind if I join? Mine will have been tuned by then and I wanna see how she goes :)
Weekend??? Sounds Doable! :woot: Missed the Nulon day cooz Friday. :(
Yeah, well hopefully ill be able to book it and ill confirm here :)
Pretty sure I'm working Nov 1st :( .. and I need money to afford new tyres for a track LOL.
I'll definitely be at Speed Weekend in Bathurst though ^_^
Damn!
What tyres you going for this time?
Speed weekend sounds like fun if I can get a working rear LSD, stupid A-LSD
Lol you will still have 3 wheel drive so go for it :P
Not at all mate :)
November 1st means that I can actually come and catch up!
Haven't seen anyone in years :D
Woo hoo! Tracking the 33?
let's go to a speed off the streets session at wakie park..
I'd be interested in this in December probably :)
Damn!
Thinking about giving the Falken RT615K's a try. They are rated treadwear 200, which is required for some events I'm thinking about doing. Plus best value tyres I can get locally :)
I hope the Ks are better then the normal RT615s cause they are the shittiest tyres I have ever used and I've had some shitters
Lol, 3wd is still not as good as 2 working rears :(
They seem to get a lot of reviews, and are apprently much grippier than the non K. Only one way to find out I guess :P
It will be good for me either way I would imagine as I have gone from Rotallas to out dated R888's and that was a great improvement, so hopefully brand new semis of any brand would still be a small improvement at least :P
I hate the RT615s with a passion, worst tyre ever and even if he Ks have twice the grip of a non K they still won't compair to R888s, so they had better have made a massive improvement, it's funny cause the tyre the RT615 replaced was a good tyre :/
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
