Nah it's not for in the car, I'll take a pic when it's finished, it's a pump in a bracket on some wood with wires to the battery and long rubber hoses out of each end to remove the need for a fuel jiggler-instead you put the Jerry on the floor next to the car, hook the wires onto the battery (alligator clips), put one hose in the Jerry can, the other in the fuel tank then switch the pump on and wait till the Jerry is empty. Means no spills and no need to hold the Jerry can up.
It's using a 34 vspec2 stock pump now but a faster pump would be nice. Thing is this pump was donated, and the whole setup has cost less than $40 combined ($20me $20paul)
lol you guys are lazy as fk! how hard is it to hold up a 20L gerry can? maybe need to do some weight lifting steveo!
fuel flows out of them a shitload faster than using a GTR pump or even an 044. and carrying around that rig sounds like a pain in the arse. a good jiggler (metal one) also work very well and flow pretty quickly. you also have the risk of sparks, failure, or if not paying attention it will start overfilling the tank and pump fuel out everywhere.
Richard its got a purpose; between sessions at Huntley when the suns out its bad enough having no where to sit or get out of the sun on a 30degree day, then standing there sweating your ass off holding a can - f that. Most would just sit it on the boot but thats too much weight and the potential to scratch the paint is too high.
The whole thing isnt even as big as a helmet so it takes up virtually no room.
We tested it the other night, its very close to the same speed as the jiggler (metal).
No chance of overfilling, we always run the tanks at a quarter tank down there, so only one jerry goes in at a time.
Pauls a sparky for work and wired it all up, i dont think there's going to be sparks - this isnt some dodgy "touch these wires together" job to get it working.
If it fails, we can get another pump for free and the jiggler will always be in the back just incase. Been using the jigglers now since converting to E85 and it was fine at first, but now its annoying so this solves that. Also it gets all the fuel out of the can, unlike the jiggler which can never seem to get every bit
Haha. Take it easy! Why stand there holding 20+ Kgs when you can have some mad little contraption do it all for you! Winnah :thumbsup:
^ haha well said!
paul - u should pushing 2 full jerry cans for shoulder lateral raises as a minimum right? lol
Nah, you have me mixed up with Reefat! That bloke is a tank!
Will test tonight to see how long it takes to empty a Jerry. Might have to get the multi out and test voltages! Bigger and shorter cable to be used to get the pump to spin a bit harder? It's still in the 'prototype' phase :laugh:
dont see the point of running different pump in tank,
theres a good friend of mine that runs 402 kw on a stock pump in tank and a bosch 044 in line . the bosch is used for the higher pressure, but we have never had any problems with it leaning out.
check him out his name is
Doo Doo
only on sau
peace
Doo Doo
only on sau
peace
is he running a standard fuel rail? only last night i was talking to a mate that was telling me the stock rail on the gtst is not ideal for higher power application as the latter cylinders can suffer from fuel starvation (4/5/6)...i looked at the fuel rail on my gtr last night & it looks quite large - what diameter are they if anyone knows?
  • 4 weeks later...
Is anyone running the new bosch 1600 injectors here? It seems a few customer and now Injector dynamics have discovered a issue only found in the 1600's where flow changes with temperature...
Tony from Injector dynamics post on supra forums...
We stopped selling the ID1600 as soon as we found the problem and EVERYBODY who has purchased them will be taken care of if our testing shows that there is an issue that there's no solution for. We are finalizing testing this week and will have concrete data next week. I can assure you nobody is going to be stuck with a set of injectors that they can't use.
And the situation happens with E85 as well Krister.
Stay tuned, details to come shortly.
I feeling better now i rescheduled my tuning a few weeks back could have been $550 down the drain....
I guess this could effect all types of new 1600's not just the ones from Injector dynamics....
I was told by my local wholesaler AZNEW a few weeks ago that the Bosch 2000cc injectors are actually designed for gas, as in lpg I guess, and aren't necessarily going to last in petrol applications due to possible o-ring compatibility issues. They told me not to bother as I was running ethanol. The 1000's are fine, not sure about the 1600's as I don't know which body they are made from. I wonder if it has something to do with this issue...
Surely there would've be some failures already if petrol wasnt compatible with them they've be around for 1-1.5years. Id hate to think there'll be some angry customers if there injectors start failing and killing engines..
The 1000's look the same as the 2000's but the 1600's are longer and made from plastic and dont need adaptors....
So is the Pierburg pump installed?
Got an inline Bosch 044 at the moment fed by intank pump... but would like to hit 700-750bhp.
Interested in this Pierburg pump! :thumbsup:
not yet - i've been busy with house reno's etc...i will have it done very soon though :)
    • Nah. Was just wondering if you were having a small stroke or if there was some slur/gaf/inside joke that I wasn't aware of.
    • That was a fark up, it's Salamanca Place I was thinking of. And now I'm curious as to what potential slur/gaf I have caused with Salamander Road, ha ha!
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
