I had the same problem with a 0.82ar gt35, 3.5" exh with a tial 44mm and the gate welded as per Roy's post. The problem & fix are pretty
well documented so I'm surprised you weren't made aware by Kyle when making the purchase.....
The main problem we had when tuning was massive boost creep at higher rpm.
Who is Kyle?
We had a similar issue with our boost control/ gate/ turbo setup.
Rb25
HKS 264 exahust cam
China intake plenum
6boost t4 twin scroll manifold
custom t4-t4 twin scroll adapter
gt3076r turbo .86 rear
Custom "straight" 3- 3.5" exhaust
Started with a 38mm gate plumbed to both scrolls on the manifold and Profec B controller- would control boost well if throttle was open gently, but would creep up with the revs. Would not control at all if the throttle was snapped on
Tried changing to a 45mm gate- similar issue..
Changed to an eboost 2.. No problems
I think the 38mm gate is a little too small for the rb25 at revs..
I did read that the Profec boost controllers weren't responsive enough for some applications.. What boost control are you using?
^same problem as CMS, 38mm tial, profec b, td06 on a std 20. Changed to a TIAL 44mm but didnt change teh boost controller. Still spiked to 14psi but it wasnt as bad as 22psi with the 38mm,
We're just using a bleed valve. No electronics at all because of simialar issues to what you've said above.
6boost is being modified at the moment by ACE. It looks very impressive and we went for a turbosmart 50mm as well. We wanted to go tial but they only make 44 and 60! Should fix it. Maybe dyno time later this week.
i hope the turbosmart gate works as they have a horrid reputation for failing. althoe i havent heard any bad things about the latest gen.
hows the nerves going leading upto Supernap with a fresh setup?
Yeah turbosmart wasn't first choice but it's the only 50mm that would suit.
Nerves... Dunno. I'll tell you when I turn in to turn 1 at Phillip Island! haha
Might be my only test day although still hoping to have a go at winton also.
pics of the wing!!!!!!!!!!
Ok. sneak preview...
I still haven't seen it all together.
Supports like the one on the right. Had to be beefed up to handle the load.
CF Front diffuser and splitter also on the way...
I think Kyle recommends the 50mm gate now as minimum from what my tuner was saying. I don't know whether it was the gate or ebc that was my problem as i've since sold the setup. They are a good manifold tho
are you planning on adding a gurney flap to that wing? if not I'd seriously consider it.
No wasn't planning to. It will have adjustable pitch though.
are you doing anything to the boot lid to stop it from flexing under load?
Yep it will need massive bracing but I'll worry bout that when it arrives.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
