  • Replies 139
I'm getting ~350 - 400km per tank from 98, so I suspect my 98 tune is a little rich too (and I like teh throttle).
E85 + 20psi will be the first thing I get sorted once back from Europe in July. If I'm on 295kw @ 16psi on 98, the retune will rock my world.
How many Kms to a tank are ppl getting roughly with eflex/e85 ?
Spoke to my mate yesterday with an evo, his getting 200kms per tank @ 260awkw with eFlex...that's horrible
The best I have got was 360 just before the light came on. That's on the highway with the occasional spurt. However I I tried hard enough I reckon I could empty te tank in no more than 120km. That's on a 400 rwkw GTR though.
  • 4 months later...
I have always used the E85 from United Rozelle.
And in actual fact its E90. I test every batch i get and has always been consistent.
I have also tested our local Caltex and they had E77.
Caltex also charge more for their E85.
For me E85 is well worth it :)
i live down the road from there, how much you payng for e85??
It does vary.
The cheapest I have bought some from Rozelle for was 99.7 C per litre, that was 12 months ago. It normally hovers around $1.20 (Give or take)
As so much of the fuel system has to be replaced/upgraded, I still advocate the enlarged fuel tank 100L plus.
Hardly... most cars dont need anything to convert. Single pump with correct injectors and factory lines and hoses 400+rwkw no problems...
I don't know about other areas in sydney but near me (balmain) there are 1 united and 2 caltex's within 1km or so of me. there will be more to come too.
  • 2 months later...
Hi guys,
I was thinking about upgrading my injectors to ID2000's & switching to e85 but have since changed my mind after talking to the tuner who was responsible for the gtr which i now own.
He thinks that e85 is still not stable & even did a test on e85 recently from a Caltex servo which only had 71 ethanol (name disclosed)...imagine what this would do if your car was highly tuned for 85 ethanol?!?!
He also said that when buying this fuel, you should only buy from new servo's which have poly tanks as the older concrete tanks are reacting to e85.
Anyway, i thought i'd share this with anyone else who is sitting on the fence as i have been for quite some time, now my mind is clear 
When e85 becomes more readily available in another 1-2yrs time, i 'might' then make the change...then again, do i really need more than 400awkw?
regards,
marko
OK
this may be silly question, but ive read numerous pages on this new United E85 or caltex Eflex... I run a stock rb25det and was wondering can I run this Eflex or E85 thru my car.... none of these posts gave a definite answer? I just want to see if it will make any difference to driving and response over the standard BP98? hope someone can clarify?
regards
No you can't run it without a retune.
HEY guys, i put about 30 litres of 100 premium at UNITED, it seems that the car runs better, faster, more responsive, BUT it uses petrol in half the time, ive got about 150km out of HALF a tank... so 30 litres for 150km, thats insanely high....
I enjoy the extra poke, but its still high usage..... I will use this 100 premium for the next tank, then I will change fuel pump and fuel filter, got my eyes on WALBRO pump and stock filter :)
BECAUSE my car has a cold start issue, first time start for the day and it sits on like 500rpm for 4secs then DIES, then turn it over again and it sits on 1200 rpm for a min then kicks up to 1500rpm after 20secs.... i hope its just fuel pump!!!!!!!!!!
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
