I did some searches and came across the part number for the filter.. Z436.. though what oil do you run in a vq25det?
i would imagine 5-35 or so though want to be sure. i only know the SR20det wanted 5/30 stuff was like water though necessary for that motor..
i have also read elsewhere that nissan recommend 7.5/30 for the vq35de.
Any other filter recommend than the ryco?
Cheers.
https://www.sau.com.au/forums/topic/363629-oil-and-filter-m35/
  • Replies 149
Same filter as a VQ35, I'm using a Nismo filter (http://www.gccorp.com.au/automotive/product_info.php?cPath=54_57&products_id=145). I think most people would recommend any other filter than Ryco. Nissan genuine filter has also been recommended to me. Part number I have here is Z445.
15W40 is ideal, although I think I'm using 10W50 at the moment, and no issues whatsoever. There are a few oils around that people like, Motul 300V seems to be the easiest to get (and dearest). I'm using Valvoline Synpower at the moment, and again no issues so far although its only been in the car 3-4 weeks.
you can get a greddy filter from autobah.. same filters as s15 too.
im running 10w40 100% Synthetic GW(the last of the stash..)
at 285kw at the wheels. its the only oil that comes out like new when its time to change.. the equivelent is Motul 300v.. but thats big money.
You sure its the same filters as S15? GCC listing says its the same as a SR20DE, but theres a different filter listed for SR20DET?
SR20DE: http://www.gccorp.com.au/automotive/product_info.php?cPath=54_57&products_id=145
SR20DET: http://www.gccorp.com.au/automotive/product_info.php?cPath=54_57&products_id=144
I'm running the SR20DE at the moment.
the Motul is around the $45 for 5Ltrs isnt it ???
Discussion on the oil that one uses almost always ends in tears :ermm: . People get very opininated about type & frequency of service so I'm not saying anything.
However, Aaron, if your oil comes out looking like new you must change it too often :) . That Gulf Weestern stuff is good tho.
i do change it too often lol but ide rather do it often with the power its running. i think the difference in filters is just the size..
ive asked for s15 ones and they've fit every time..
im using the greddy ones now though which are smaller but as long as youve got the thread right and the plate size right any filter within the size will fit..
s15 350z etc..
s15 350z etc..
As I understand it.. Filter size matters! It is used in establishing/maintaining oil pressure; changing the size of the filter changes the pressure it'll run at (higher/smaller volume..); too small and it'll be running a higher oil pressure. I could be mistaken though :unsure:
If its coming out clean I would say your oil isn't doing a good job. Oils should trap contaminants that the filter will not. Every engine will get some amount of contaminants in the oil no matter how good you think your engine is.
Neither of us run that dino 98 fuel :P so the oil is usually a lot cleaner than usual(as are the engine internals), and the Sougi doesnt burn at all from what I have noticed even with multiple dyno runs seeing 110 or 120 degree oil temps. I have always changed mine at 5000 intervals using grade 5 oils only, call me paranoid but I prefer to be sure its at its best especially with the ethanol perhaps breaking it down a bit.
I used S15 filters when it was stock, now I need a larger rubber seal so I changed to a bigger M20 x 1.5 one that seats well on the cooler sandwich plate. Ryco have never let me down, unlike the Drift ones.
pfffffttt!.....yeh travelling to QLD I'd have to carry Jerry can's....fun fun fun!....btw....when are you going to finish your tune :P
lol yeh i dont know. im trying to figure this boost control issue..im gonna pull the spring off the actuator n see if anything changes... but i have a feeling its the actuator not allowing "full travel" of the wastegate flap.. dont know why but ive opened up the wategate and nothing changed.
Slightly off topic but kinda still on...
What do you guys use as far as the rest of the fluids? My M35 will be here soon and I plan on giving it a big service so I know where I'm at but just looking for advise as to what peopl run... Engine/Trans/Diff/Altessa?
Much thanks :)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
