I did some searches and came across the part number for the filter.. Z436.. though what oil do you run in a vq25det?
i would imagine 5-35 or so though want to be sure. i only know the SR20det wanted 5/30 stuff was like water though necessary for that motor..
i have also read elsewhere that nissan recommend 7.5/30 for the vq35de.
Any other filter recommend than the ryco?
Cheers.
https://www.sau.com.au/forums/topic/363629-oil-and-filter-m35/
  • Replies 149
Same filter as a VQ35, I'm using a Nismo filter (http://www.gccorp.com.au/automotive/product_info.php?cPath=54_57&products_id=145). I think most people would recommend any other filter than Ryco. Nissan genuine filter has also been recommended to me. Part number I have here is Z445.
15W40 is ideal, although I think I'm using 10W50 at the moment, and no issues whatsoever. There are a few oils around that people like, Motul 300V seems to be the easiest to get (and dearest). I'm using Valvoline Synpower at the moment, and again no issues so far although its only been in the car 3-4 weeks.
you can get a greddy filter from autobah.. same filters as s15 too.
im running 10w40 100% Synthetic GW(the last of the stash..)
at 285kw at the wheels. its the only oil that comes out like new when its time to change.. the equivelent is Motul 300v.. but thats big money.
You sure its the same filters as S15? GCC listing says its the same as a SR20DE, but theres a different filter listed for SR20DET?
SR20DE: http://www.gccorp.com.au/automotive/product_info.php?cPath=54_57&products_id=145
SR20DET: http://www.gccorp.com.au/automotive/product_info.php?cPath=54_57&products_id=144
I'm running the SR20DE at the moment.
the Motul is around the $45 for 5Ltrs isnt it ???
Discussion on the oil that one uses almost always ends in tears :ermm: . People get very opininated about type & frequency of service so I'm not saying anything.
However, Aaron, if your oil comes out looking like new you must change it too often :) . That Gulf Weestern stuff is good tho.
i do change it too often lol but ide rather do it often with the power its running. i think the difference in filters is just the size..
ive asked for s15 ones and they've fit every time..
im using the greddy ones now though which are smaller but as long as youve got the thread right and the plate size right any filter within the size will fit..
s15 350z etc..
s15 350z etc..
As I understand it.. Filter size matters! It is used in establishing/maintaining oil pressure; changing the size of the filter changes the pressure it'll run at (higher/smaller volume..); too small and it'll be running a higher oil pressure. I could be mistaken though :unsure:
If its coming out clean I would say your oil isn't doing a good job. Oils should trap contaminants that the filter will not. Every engine will get some amount of contaminants in the oil no matter how good you think your engine is.
Neither of us run that dino 98 fuel :P so the oil is usually a lot cleaner than usual(as are the engine internals), and the Sougi doesnt burn at all from what I have noticed even with multiple dyno runs seeing 110 or 120 degree oil temps. I have always changed mine at 5000 intervals using grade 5 oils only, call me paranoid but I prefer to be sure its at its best especially with the ethanol perhaps breaking it down a bit.
I used S15 filters when it was stock, now I need a larger rubber seal so I changed to a bigger M20 x 1.5 one that seats well on the cooler sandwich plate. Ryco have never let me down, unlike the Drift ones.
pfffffttt!.....yeh travelling to QLD I'd have to carry Jerry can's....fun fun fun!....btw....when are you going to finish your tune :P
lol yeh i dont know. im trying to figure this boost control issue..im gonna pull the spring off the actuator n see if anything changes... but i have a feeling its the actuator not allowing "full travel" of the wastegate flap.. dont know why but ive opened up the wategate and nothing changed.
Slightly off topic but kinda still on...
What do you guys use as far as the rest of the fluids? My M35 will be here soon and I plan on giving it a big service so I know where I'm at but just looking for advise as to what peopl run... Engine/Trans/Diff/Altessa?
Much thanks :)
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
