I finally got time to fit the GTX today, let me say now its bloody huge and only just fits in there. It sat a bit lower than I hoped too, I need to make a 90 degree oil drain to make it work. Everything else, although tight and time consuming, is easy enough to make now. Heres some idea of what I am dealing with...
Thanks Aaron for the help, we set a new record of 1 1/2 hours to remove the stock turbo. :thumbsup:
https://www.sau.com.au/forums/topic/368795-gtx3071-install/
Mmmm...
So when will it get fired up for the first time?
Plenty more work to do yet. :/
There is 5mm clearance from the gearbox housing and 10mm between the compressor housing and the chassis. Literally the minimum I would allow. Lucky our engine mounts keep it nice and tight so it should be fine.
https://www.sau.com.au/forums/topic/368795-gtx3071-install/#findComment-5880299
Na, metal contracts when its heated. She'll be fine :ninja:
not if the engine tilts towards the firewal..
lol the first fit the wastegate entry was touching the wall.. i think after i left he re welded the adaptor.
https://www.sau.com.au/forums/topic/368795-gtx3071-install/#findComment-5880469
dampers are shit and useless
engine mounts are the ONLY way to do it properly
i think the engine twists in the opposite direction anyway. but backing off might make it bump the sidewall?
i think the engine mounts are near solid anyway.. only better ones i think are the nismo ones which are completely solid..
agree with you on dampers.. havnt seen one thats worked as good as doing mounts.
https://www.sau.com.au/forums/topic/368795-gtx3071-install/#findComment-5880659
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
