Yeah man, in the drawer right next to my Veet and spray tan
I just went wtf is veet... Then google was my friend, and I went ahh f**k that I would rather pay someone to do it...
So Troy, I have to ask... How does it feel to momentarily seem like more of a woman than someone who has a vagina, an obsession with disney and her world revolves around sparkles and the colour pink..? :no:
hahaha pretty girly :P
Just read through the thread couldn't find how much u weighed to start with and how much u weigh now....
72kg when he started, 75kg currently
72kg now, aiming for 80kg by summer with preferably the same BF% as before my trip, or less :D
Back up to 74.5kg naked weight before I eat dinner, happy with that progress :)
Starting weight would have been about 71/72kg with decent body fat. Current weight is ~74.5kg with much less body fat.
I weighed in at about 74kg prior to going overseas for 6 weeks. When I got back I had lost 2kg and put on noticeable fat - which meant I'd lost a fair crack of muscle mass. That is the point that I "started" this thread.
I haven't quite been eating enough to put on much weight - coming into summer I've been very indecisive about my goals and have settled with toning and defining mostly.
Also should note I feel like a bag of shit. Got myself a REAL nasty cold over past 2 day - was up all night last night with a fever and raging headache, hallucinating and shit. Good times.
on the 28th of December (2005) I received a late Christmas present in the form of a blood clot in my occipital lobe. I had a stroke at 17 and a half years of age, which rendered the left side of my body completely useless (for only a short time mind you). It took me a few days to regain movement and feeling, and I was released from hospital a week later, walking etc again - albeit a bit f**king uncoordinated. Unfortunately, even the thought of attempting to play soccer again that year was a joke, and so the constant exercise almost came to a complete halt.
Sounds pretty full on, do they know what caused it? Has your coordination returned?
No idea what caused it - (from memory) since it was almost certainly a dislodged clot from somewhere else that got caught up there, it was suggested that perhaps I twisted my neck and tore one of the arteries running up along my spine....then just by bad luck, the scab that had formed broke away and got stuck in my brain haha. Otherwise there was speculation about many other things like the tiny hole between chambers in my heart (that like 30% of people have anyway) allowing a clot to pass through rather than be filtered by the lungs or something. In the end I spose it's just bad luck and shit happens really. I didn't want to dwell on it at all - just wanted to move on and get back to "normal"
Regarding my coordination, honestly I'd say that I'm ever slightly more gumby than before haha particularly my left side. Though the only thing I ever notice is slight clumsiness on occasion and the blind spot I have in the upper-left of my vision field. When it comes down to it, nah I'm perfectly fine as far as my life is concerned. Just a little disappointed it stopped me from joining the air force as a pilot or at the least getting my pilot's licence. Ah well.
Feeling a lot better from the cold, just got a bloody annoying dry cough now...though I still shouldn't have stayed outside in the cold and rain yesterday at Foreshore lol....shorts and a singlet don't do well for keeping you warm!!
Squats:
60kg x10
90kg x10
90kg x10
120kg x10
140kg x6
140kg x4 (legs went to jelly on the way down for number 5)
DL:
60kg x10
90kg x10
90kg x8
Was far too buggered to keep going on :( oh well feel good and that's all that matters.
Good squatting, how's your flexibility with these (what's the depth like)?
90kg and under I can pretty much get down to almost sitting on my heels....above that weight and I can't quite get that low lol...
FLEXIBILITY itself for squatting is fine, it's just the strength and a bit of balance I don't have to go all the way down on higher weight
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
