6 x Xspurt 1000's and Proflow RB25 rail would be around $800 through me I think Mark, with all adapters.
Scotty - will that rail fit with the stock plenum? We are looking at going to E85 in the next few months, so I am interested in an injector upgrade.
I think so mate, the 1000's might be a tight fit, but the shorty 750's and 2000's are definitely no issue. I may even be able to get 1000's in the same shorter 1/2 length.
The SR20 rail kit I sell comes with a plenum spacer to help the 1000's clear the upper plenum. Perhaps you could do a similar thing to the RB plenum halves using bakelite or a similar insulating material, that way you would stop the heat transfer into the upper plenum also.
What paper filter are you using, I was told to be careful when use paper filter cause the ethanol can/does eat away the "glue" that holds the filter element to the casing
I'm using a speed flow 10 micron stainless sceen filter but the paper ones can go down to 5-6 micron which would be better
I am using twin Proflow stainless mesh filters, I haven't cleaned them in 3-4 years, since they were installed. I can't remember what micron they were...
The paper filters I have been buying were SX brand, suitable for alcohol fuels. (They have a similar 8an housing to the proflow/Speedflow style filters, and might just drop in to them.) I run the SX fuel reg in my car without issues so I knew it was good gear.
A little Googling reveals Arram as a Japanese manufacturer who make injectors, throttle bodies and carburetors.
Yeah, just wasn't much info and didn't know if these were common in rb20's or not.
Most of the stuff says 550cc, so should be all good, cheers. ;)
Hopefully it doesn't cost you too much dyno time to set them up, it can take a while to work out suitable lag times etc with unusual injectors, and you are paying good coin for every minute it's on the dyno.
Unless you have the lag time report with them? Might be worth trying to source one.
Never knew injectors even came with a "Lag time report" lol..
I was going to get them tested and flowed before I chucked them on anyway. I think they're a little old.. :P
  • 3 weeks later...
  • 4 years later...
To save starting a new thread.....
Is the contents of this thread still relevant?!?!
As in are the ID injectors still worth paying basically twice the price or are the EV1-Bosch items closer to the mark 5 years down the track?
(Looking for 11mm units to suit standard RB26 fuel rail to get me around the 400rwkw mark on E85...)
ID1300x or 1250cc.....?!?
Edited by mr_rbman
There are better options (than ID specifically) and have been for years.  You should perhaps PM Scotty to find out what he can do for you.
Basically, if you can get unmolested EV14 injectors in the size you need, that is best approach.  But even the ones that have been decapped are pretty good.
I had tried pming Scotty before posting but either his inbox is full or there's an SAU issue as i just get an error saying he can't receive messages, or something similar....
Cheers for the reply though....
I do have the 1250cc injectors that Kudos sell in my 'cart' but after reading a few threads on here and then googling I was having second thoughts....
Tier 1 - ID
Tier 2 (½ the price) - Bosch Motorsport
Tier 3 (aka shit and not worth it, also ¼ the price) - Everything else
Genuine Bosch Motorsport '040' injectors with adapters for RB26 manifold would be the go. I'm sure NZEFI sell them as a kit.
  • Like 1
    • Before I commit to it as I already have the wastegate off the car, would you change it to the 9psi spring instead of the 12, or whack it back on now and try your suggestion?   Edit: Actually I might just swap the spring and see what the logs say after another few pulls, as we know it's still spiking without the Mac valve in the picture so I need more data without the Mac valve trying to combat the issue.
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
    • Car has been sold and I am now selling leftover parts. Prices are non-negotiable as I will sell to my mechanic if it won't sell here. Prices are firm except for the Random Parts listed at the very bottom. All parts are genuine except for the S-Tune front bumper. Volk Racing TE37SL 19×10.5″ +12 5×114.3 pressed graphite with P-Zero 275 30 19 tyres [USED] $4,500 Wheels are in perfect condition, have been sitting in my garage for the past 6 years. Tyres still have 90% tread, but since they're now old, I would not recommend you drive hard on them. K-Sport Super Sport External Reservoir Coilovers (made to order) [NEW] $2,500 Front spring rate 14kg, Rear spring rate 7.5kg Fork Type. You can read all about it here (https://www.k-sportracing.com/product_detail.php?Key=12). I was going to start tracking the GTR, but never got around to it. Paid $3500 (after USD conversion and taxes). HKS Kansai Service Tower Bar [NEW] $500 Never fitted in the original Japanese box. R34 GTR S-Tune Fibreglass Bumper [NEW] $500 No mesh - No Box - No damage - just dusty. Nitto RB26 Clear Timing Cover [NEW] $50 Couldn't fit RB2630 due to bonnet clearance. HKS Piping Kit Special Type (BNR34) & Apexi Power Intake Air Filter Kit & Password JDM Adapter [USED] $1,000 Missing some rubber hoses and supports, but you get what you see. Nismo NE-1 Weldina Turbo Back Exhaust & Custom 3.5"straight pipe [USED] $1,000 Needs some love, but perfect for those who want to go back to OEM+. Bayside Blue Aluminium Vspec Bonnet/Hood [USED] $700 Came off my GTR. Unfortunately, the tips have been slightly ground down. It will need some repairing. Bride Low Max Super Seat Rails [USED] $350 The price is for both sides. Will post pictures when I get a chance. Random Parts [USED] - negotiable Standard rb26 cams (intake and exhaust) $10 Stock amber front indicators $10 Standard GTR bumper lower side grills $10 Stock amber side indicators $10 Nismo Sports Resetting ECU $50 Water reservoir $10 Stock airbox mouth $10 Stock fuel rail $10 Stock coilovers from R34 GTR Vspec $100 PM me which items you are interested in. I do work 9-5, so I will be responding daily at best. Best time for pick up is after 5 and before 7 on weekdays, or i can work something out on weekends. I will only accept cash or PayID. Pick up only - located Epping NSW area.
