  • 6 months later...
Been pretty lazy with this.
Car is currently on Jack stands getting the brakes powder coated and rebuild.
While I can't drive it I've gone on a bit of a restoration spree.
New front emblem
Had to sort out some braid rubbing on my intercooler. Not happy with how it was installed so ripped the whole front end apart to fix the lines.
I have this waiting to go on my car to finally complete the exhaust to go 3"-3.5".
Also my mines exhaust was getting a bit tired so it got replaced with a HKS Super turbo. Really nice sounding exhaust but nowhere near as nice as my mines was. It shoots bigger flames though.
Lastly anyone know of a side skirt fs in mnp in good condition? I hit a bit of timber on the freeway a while ago and it literally took a chunk out of it! :(
  • Like 1
Much better condition steering wheel. Put the standard gauges back in, but still keeping water temp and AFR.
70646F5E-31BC-4EE2-875D-7698D7855C46_zps
Deep cleaned the interior
DFE9295C-D919-4A76-BEDD-0E8E809E361B_zps
Painted windshield wiper arms, they were getting tired. Also put the new design wiper on the car. Hope that stops it hopping around.
D28ABA74-6CE2-4BBC-A2A7-8D48A1778515_zps
Look at this mess
And now its just sitting here waiting or is it flying? haha
DE7CC5E8-A193-4453-9430-48147D4608E9_zps
Oh and whoever said you can't get a screw driver through a oil filter on a RB26 is joking himself. I had to resort to that because a certain mechanic has the grip strength of 20 Thors and then calls me weak.
  • 3 weeks later...
Look what I picked up today
Looks like I have a weekend of brake fluid ahead :S, I dont like brake fluid, why do they make so toxic and virtually a paint stripper?!
FAC399FF-5329-4BD5-BDA4-60D63D9B016F_zps
Cheeky little test fit. I know, I know, boring colour. But I like the stealth look.
1D2DBC9C-5730-46E0-A1C4-F48B50DA1159_zps
  • Like 2
On the street the brakes do not fade. It is street driving after all.
At wakefield the brakes did great. I was running Nulon super dot 4 and QFM A1RM pads on the front at the time. I could do about 5/6 hot laps before the brakes got a bit spungy. Both times I went it was 30+ on the day which sucked. Got a 1.08 at wakey.
By this time I must have proper cooked the brakes because they were all squeely and shit driving back to gosford, so I pulled them out and slapped in a set of Intima pads. I think they were the SR pads. Now for me personally they were shit, I had brake fade within 2 laps of the first session at eastern creek south circuit and they didnt have the same stopping power as the QFM's and I destroyed the pads at one outing on the track. Even though I was not impressed with the brakes I still pulled a 1.04 at SMSP south circuit for my first time there.
The real guru to speak to standard brakes vs bbk is fatz. Look at his thread he will tell you what is what.
Pleasure.
So brakes are on. New brake pads are in but not without some elbow grease.
The front brakes didn't fit width wise in the caliper. So out comes the file and file 1mm off each brake pad. Thanks powder coating and your thicknessness.
Rears had no problem. Fit like a glove.
That's it for tonight. Tomorrow is brake fluid day. Yay my favourite.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
