Cool cheers.
Spent 6 hours washing, polishing and detailing the GT-R last weekend as it had been in a workshop for 6 months so not afraid of some hard work!
It is going back for some more work soon so will clay/polish/wax when I get it back.
Collinite is the bomb. I'm also a big fan of Naviwax Ioncoat, its a Japanese product very similar to Collinite 476 but is applied to a wet car and removed while drying the car. Zero streaks and takes about 10 minutes. Too bad it's discontinued now
  • Like 1
Update.
Federal Australia have agreed to give me 2 new tyres to try out in the RSRR as they do not make the RSR anymore.
Putting them on the car on Saturday so now I can try them out for free and if I don't like them I sell them.
  • Like 1
Indeed.
Read on some Evo forums that the sidewalls are much stiffer on the rsrr and grip is apparently on par with rs3's. We will have to see.
Also, collinite is being heavily tested by the great nsw weather we are having. Seems to be performing swell.
  • Like 1
Got these guys in the mail today.
B0F3404A-6038-4243-BC7E-2E15293186C7_zps
Out come the back seats and parcel shelf.
The one on the driver side was quite a pain due to that ecu there. I put a couple of washers on the front screw and then bent the other bracket so it would give me more clearance.
C67B3627-BBE2-4E3B-8141-FCD014BEFFD0_zps
The plug clears well and there is no tension on the wires, so great success.
Passenger side easy peasy.
F9EF5F7F-27DC-4566-B7F1-603C536E2B02_zps
And then put everything back together again.
1BE95E6F-6B06-4336-91CE-7FD99070819E_zps
FCDE1936-3F59-4F9E-B64D-83679F3BCDDC_zps
At least those child restraint holes were good for something.
Oh and sometimes people ask, can you install 6x9's in a skyline?
Yes you can, was one of the first things I did 4 years ago.
B6E0B26F-3E11-4350-89E3-072CB197AB53_zps
Now I dont have to dismantle the whole rear of the car to play with coilover stiffness. Such a pain sometimes.
  • Like 1
Got my Rs-RR tyres yesterday. 2 RR on the front 2 old R on the rear.
Jeez these are good. Bit noisy at 70 but wet weather grip is phenomenal. Better than the RSR's when they were new.
Steering feel is great, they feel responsive. Im happy to get 2 more I think.
Genius!
Child restraint holes through the speaker grill??? lol.
Read a bit of your thread mate, awesome car, love the colour, wheels, ride height. 10/10.
I remember years ago in my S14 drift car I had 2 federals blow out, while still having decent tread left, and they split across the tire, very similar to yours.
Scared the hell out of me, as I was in 4th at the time, so wheel speed was up, haha
  • Like 1
So unfortunately not able to make any new record top dyno numbers today. But at least it's only a number and I'll see what the quarter has to say.
Anyway, after the new dumps/front pipe and cat back the curve shifted left. Which is great, more midrange but top end dies.
Jez just had to put the 1 psi back in that it dropped. Other than that the tune was sweet.
Soooo, the reason for the drop could be a number of things. No air leaks which is great but then again could mean motor is getting tired or the cat kinda is dying haha.
I will investigate further but not worried as the car feels great.
Green was tune 2 years ago on standard dumps, spaghetti front pipe and old post-84720-14474898611319_thumb.jpgcat back.
Red is new with beefy exhaust system.
  • Like 1
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
