Ever wondered how big an ECU was...?
The file I have is just 1mb of binary. For a very complex machine, the file is kinda small I thought....
When you're not making pretty pictures, you can cram a LOT in to 1mb. Im actually surprised it is that big.
Looking forward to hearing of your success with Uprev :cheers:
Well, today I dumped the ECU with the UPREV software and cable. 3 and a bit hours of waiting! Oh well. its done now. I have emailed it off to Abbey Motorsports in the UK. They are going to tell me if I can use the uprev software, which I am almost certain I can, and give me something able to be tuned and flashed!
Forgive my n00bishness but could something like this be used to dump a VQ25det Nismo ECU and then flash it onto a standard VQ25det ECU? Sharing the increasingly rare awesomeness with us all? I know our ECU is different but if we were just basically copying the settings from one ECU to another?
Well not exactly. The Japanese, places like G-Zone, can remap the VQ25DET ECU. Not a direct swap of the Nismo, but probably better because it's tailored a bit more.
Not entirely true that statement.
The Nismo is not an off the shelf ECU tune but it is tuned on each vehicle that the Nismo ECU is fitted. Removing most of the low RPM throttle restriction and improving response all the way through the rev range.
you thought wrong :P
thats why there are no part numbers for the ECU, they are unique to each car. however AFAIK they are done with the factory options so we mostly have those as other brands.
I bet no Nismo ECU is tuned for a car with a big fat intake???
As far as I can see, the problem with any of these pre-programmed ECUs is they can't be optimised for our cars which are all a bit different. In some way they have to be "best fit". If only some enterprising person over here would learn how to hack the damm thing & offer customised tuning. Otherwise we continue to tinker around the edges without getting right inside.
At the moment I don't think the volume is there for the time required to hack it. Can't see anyone putting in all the time and effort to tune maybe 20 cars in Australia that would want it done. This is comparing it against S13 and the likes where they would do more than that amount in a week.
Remember that some people tune for economy and performance, I suspect that a lot of people that buy an M35 for reliability and purpose would consider getting it tuned to improve economy too. There's more and more of these things kicking around Adelaide (and just about every one I see is modified), so I can't imagine how many are in the Eastern states!
The way I see it you guys have these options-
A) Go to the Russians. They might be crazy enough to pay for someone to do all the work (on the other side of the world they're probably sayin: Австралийцы достаточно безумен, чтобы сделать это )
B) Get G-Zone or who ever to licence their technology and some workshop in Aus buy the set up off them.
C) Deal with what you got, because I don't think anyone in Aus is going to crack it.
Edit
D) Motec. forgot about that.....
Thoughts?
Edited by PN-Mad
I reckon someone will at some point.
I have a spare ECU that I can send out and had a place in mind down here (they create racing ECU's and are in Bayswater I think), but I can't remember their name to contact them :(
A good mate of mine is one of the 2 guys that are Nistune and I asked him a while ago about cracking it and it's not worth their time at the moment as the market is too small for the time needed compared to all the other models they have on the go.
Its not only the market, but Nistune haven't moved into anything with a CAN Bus electronics.
Stuck in tractor land....
Spoke with him again. It's because the newer stuff is flash based so totally different to what they sell now, here and world wide. So it's an all new R & D for it. He said its something they will look at in the future but not any time soon.
They are very busy with the current Nistune gear. They have done an awesome job making tuning affordable for the cars that are currently supported. And keep in mind that this is a 2 man show.
Edited by slippylotion
So because a few of us m35 wankers need something it becomes out of their league? Your most welcome to crack if your all so capable!!!
And let's not rubbish a business for not yet looking into something we want in low volume. I was simply letting you guys know the outcome from me asking them about it
So stop the rubbish talk, we aren't children!
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
