Will you be working at "The House of Stagea" tomorow? Might see if I can nip down for a perve...:whistling:
yup....he will be there...I have a couple of small projects on the run I want to finish and I'm sure his Aric wants to bolt all his bits back on.
Fairy Muff... I'll give you a bell tomorrow.:thumbsup:
Its a great idea Dale, but there is stuff all room there. I'm running about 4 or 5 hoses in the area already.
What I really need to know is does it matter being before or after the AFM?
Ideally you want the BOV as close to the throttle body as possible and certainly between the afm and the throttle body.
The pulses reversing through the AFM would almost certainly cause issues.
1327738925[/url]' post='6207971']
Yeah, that's the conventional thinking. Thing is, I has no bov now, and it doesn't seem to suffer any ill effects other than the comp surge. Nil afm issues. The afm will only read in one direction.
That's why I'm a bit puzzled.
because your afm is in the cooler pipe you can actually have an atmo bov if you wanted to, so long as its on the pressureised side of the Turbo (duh) and pre afm
At this position the afm hasn't metered the air yet so loosing it to atmo doesn't matter
You could also put a recirc bov here, or after the afm, but a recirc bov is probably best after the afm to prevent reversion and air going backwards through the afm on closed throttle
So was there a question about where to locate it or are you happy with how the car runs? The reason you want it close the throttle is to release the pressure as early as possible to shorten the pressure wave. There are lots of cars that have the BOV located somewhere further away and it works but it is not ideal. Conventional thinking is there for a reason.
Last I checked pulses of air moving across the afm element, changes the afm voltage regardless of direction.
Conventional thinking doesn't have the AFM 300mm from the TB and the intake about 1800mm from that. The afm is not designed to pick up air travelling in the opposite direction, it would be very much shielded from the path of the air reversed, thats what I figure when I look at the thing. At the moment I can't say there is any ill effects in driveability because of the air backing up, just the comp flutter, which is actually a little milder that what I initially thought.
If it was going to be easy, I'd put it before the AFM, problem is I have very little space there anymore.
Scotty, I do care about the noise. In Sydney run a external BOV and your classed as full hektic- bend over and get ready for the po po.... Funny thing is with the flutter, they would think its a BOV anyway.
Edited by PN-Mad
Cam, Below is what I had to do to the Fnt bar. nothing drastic - just one cl ip to go, and a bit of sanding to clear the top cooler pipe.
All done!
I'll get some underneath pics, just have to get it up the ramps!
Looks really neat Alex. Well done to all involved thus far.
What does HKS suggest re BOV, if anything? Surely they gave detailed engineering info, like how they acheived their design criteria for a truly bolt-on/no mods necessary kit such as yours, lol.
And you don't strike me as the fully hektic type that goes around looking for trouble. I'm sure there's a solution somewhere...
Thanks Alex. I was wondering how far the grill came back to the intercooler recently actually.
Oh, and nice little shroud/box for the pod, any point to the stock air funnel now though? are you going to route air from it to the pod?
No point really to the duct. Its not in there now. The pod gets heaps of fresh air from below, through the grill, and up near the wheel arch.
Craig has taken to writing HKS on various things on my car now. I have to say the bracket he made up for the trans cooler is a work of art.
Edited by PN-Mad
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
