Would the first sensor be receiving too much (ECU is expecting gases from 3 cylinders, not 6) while the second sensor is not receiving enough due to the gas flowing around the first sensor?
Might explain the differences in fuelling each bank to compensate?
Here you can see some data- % correction is on the left, and inj pulse on the RHS, in the middle you can see the Volts from the "A/F WB bank 1 and 2"
See how the inj pulse is uneven, and the ECU is factoring in a correction, even though all 4 sensors are reading very similar results?
Thats a fail.... I'll see if I can format it to work here...
Edited by PN-Mad
The ecu is trying to cycle the afr's and expecting the o2 sensor to pick it up for that bank. As you now have the two sensors in the dump it cant differentiate between the signals as they are merged as one. Did you make sense of that? Just switch the o2 feedback off and get a tune, you won't need learning hopefully.
What Scotty said is entirely correct IMO. As everyone knows, in closed loop the ECU cycles the injectors rich/lean & gets feedback from the O2 sensor/s. When it leaned off one bank & read the AFR from that banks' sensor, it was really reading the richer exhaust from the other bank. So it leaned it off a bit more, check - no difference, continue reducing injector pulse width until reaching end of ECU parameter (result is you get a rough idle or whatever).
When you pulled the O2 sensor off & put back again, it just so happened it was the other bank that started leaning off first & the cycle continued as before. Point proven I reckon.
Funny, I recall questioning this layout when I saw the pics (page 3?) because I couldn't see how it could work. But since I'm no engineer (well not an automotive one), I wasn't about to call it a HKS design fail back then. But now I think it is- just a little bit, lol.
Ideally the sensors should be moved so they are sniffing the AFRs in their own bank, but that's probably too hard. Disconnect so never run in closed loop....?
I hope you get it running how you want it Alex. It's looking great nonetheless.:thumbsup:
Thanks Leon.
I guess putting a o2 sensor in the drivers bank is possible, but with the size of it I would say it would be terribly restrictive. The pipe really isn't sizeable compared to say the dump pipe. And with the restriction, it wouldn't read right anyway.
What would happen if I spliced one O2 sensor, and connected both the banks to one O2 sensor? Those with sharp theoretical minds- not me at this hour....
Just to put it out there, this problem seems to have been experienced with 350z's- running high flow cats and the like. So I don't know how that works, because they still have bank dependent O2 sensors.
http://my350z.com/forum/tuning/478308-unique-problem-bank-1-overcorrecting-rich.html
Its running open loop for the moment. I hope I can get it closed somehow because there is benefit there- I can feel it in the "drivability"
Personally, I think you may have to accept that there's no real way to trim injector duty cycle for each bank with the O2's in the current arrangement.
As Scotty & Leon have said; the ECU is making an adjustment; not seeing the result it wants on the particular O2 sensor that should be showing a change; rather it sees a condition across all four O2's which it doesn't like. It then continues adjusting; trying to get the result it expects, until it actually affects driveability.
There may be a way however; within the UPREV software to change to adjusting both banks of injectors as a unit rather than individually (and reading all 4 O2's as one; as per the VQ25DET). It might be a simple as a line of code. It won't have the pinpoint accuracy of the OEM setup; but ti would still be pretty damn accurate. I can't see another solution; unless you physically move the O2's into their respective manifolds.
Dale, what you suggested is a good idea. Having read some the posts on 350z forum (& seeing how many people have a similar problem), I'm surprised they haven't been asked this question before.
http://my350z.com/fo...cting-rich.html
Mmm, I don't think splicing them together would work. Typically in electronics when you double something up you halve something else. Worse case scenario you could blow up that input into the ECU because the impedance or voltage is too far wrong.
It is very confusing Alex. I stand by what I said before (co-located sensors can't differentiate AFR between banks), BUT why do the 350Z's experience a similar problem (albeit not quite the same by my understanding) with O2 sensors located on each bank.
Is there an inherrent ECU logic problem with the 350Z & PNM computers that only manifests itself when moved sufficiently away from stock, ie better exhausts/intakes & def FI?
As you said, it would be really nice to get the closed loop running right. Lots of benefits in fuel consumption & smooth driving to be had. I'll keep reading....
Tonight, Jetwreck and I dropped in the Injectors, changed the plugs, and fuel pump. Tune will be on Thursday. In the process I cleaned up the inlet tract- a bit of oil in there, not too much, and some ugly looking black stuff behind the throttle.
What we thought is that we should have a bit of a guessing game as to the power that it'll kick out. To give you the low down- Its a 3.5 litre V6, 10.3:1 compression, 600cc Injectors, HKS GT3037 pushing 0.35BAR or 5PSI, full 3 inch exhaust with HKS Cat. Automatic box. Car will be tuned in RWD.
Jetwreck guessed 223rwkw (right?)
My guess is 235rwkw
Post em up- see whos closest!
On with the Pics-
Down zee hole- for anyone who hasn't see one...
Spacer = more room to fill = more lag and less throttle response.
Trawled the net to find benefits for FI 350z/G35s with the spacers- but could find anything. No doubt beneficial for NA cars- but when air is pressurised, I think the effect would be less pronounced- prove me wrong, I'd love some real info.
Edited by PN-Mad
Did you feel noticeable lag off boost after installing the HKS kit?
Just wonder how much extra air was needed to fill all that piping and intercooler space.
I might be wrong, if there was some lag from filling the extra volume (say 10mm plenum height) it'd be negligible.
I also haven't heard of anyone noticing increased lag after installing a 19mm runner spacer on a VQ25det (closest I could get to increasing the area between the combustion chamber and the TB).
How hot a day will it be? What's the barometric pressure & humidity?
242rwkw.
Lol, says me with such confidence (I've never seen a dyno run in real life). Good luck & I hope you get a nice surprise.
21 to 26 degrees. Cloudy, rain periods with heavy falls possible. Sounds like high humidity, Currenty it's 1014.1and rising.
The runner spacer volume is tiny compared to the spacer that 35s run. I'd take a punt volume wise, that it's be 10 times the volume. Remember, when you snap the throttle shut, the motor has to eat all the extra air in the plenum before it starts making vacuum. It's not a massive thing, but I just don't see the point on a fi motor. The tendency is to make smaller plenums. Yeah, I'd love a cosworth, they are no good for na motors.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
