Yup - airbox with pooer duct.
Mine wasn't really different when it had the Pod and the AFM after the turbo anyway (besides on boost). The Pod had epic cold air from the front wheel arch.
The Kinetix plenum is massive thermal improvement on the alloy unit. can pop the bonnet and still put your hand on it after a long drive, where you'd end up with 2nd degree burns from the stockie.
Well, taking the barge out to the "CAMS Come and Try day" on Saturday, so might have some track / texi footage up soon.
Its on the Eastern Ck South circuit, and the skid pan. Its not a full on track day, but more of a taster of a couple of motorsport disciplines under the guidance of more experienced people.
I have given her some fresh pads, fixed the sump, and going to be bleeding the brakes on Friday. Didn't get a chance to get a tune on it, but stock map is supersafe, so won't have any issues on the track, except for fuel consumption :P
Will also be interesting to see what temps I see after all the cooling system overkill for a NA car.
CAMS come and try day :
Firstly - Thanks to JETWRECK, WAGON_BOY, and ANDY65B (or whatever it is) for coming out with Cameras and stuff! Great to see you guys as always.
Had a great day - fun/non serious atmosphere, loads of variety of cars. Very nice BB BNR34 GTR in the last session, and a few other Lines out there.
Besides the "speed limit" I did manage to get up to a sneaky 140km/h down the back bit. Instructor was great - very informative and calm. Instilled a good level of confidence and level headedness. Motor held up fine - bloody over engineered the cooling system so the thermos didn't even switch on. Brake pads were the first thing to start to go, but only had a long pedal a couple of times over the sessions. Pity the traffic was so heavy. Would have liked to have at least one good timed session, but was stuck behind quite a bit of traffic.
Motorkhana times- I did 4 runs.
RWD: first lap - 33.82 then 31.82
Put the fuse back in so AWD
30.38 and best time of 29.67 before I pulled aside.
Got a round a of applause from the timing crew, so I don't think many were below 30 secs. Hope they put the times up, but don't think they were officially recorded. Only other sub 30 sec time I heard was an Audi quattro wagon. Wagon FTW!
All in all a great day!
Now I know there is Pics and Vids of the Texi / Track- so please share Craig/Theo/Andy :)
skid pan pic's...........
(due to operator error and shi**y weather/cloud cover i f**ked up the shots from the track most of them are pixelated/blurry) FFS!!! :(
further pic's can be found here https://www.facebook.com/media/set/?set=a.412390738841117.96686.192043784209148&type=1#!/media/set/?set=a.412390738841117.96686.192043784209148&type=1
Edited by WAGON_BOY
Don't know about "at home" but it sure did surprise a few people, and did not disgrace itself.
Very fortunate to have such awesome people in the community. Thanks for the vids/pics guys.
I felt them overheat a couple of times. They aren't race spec, more high performance road. Fluid was fine, I only got long pedal once, and after a couple of corners it was fine. Overall they were pretty good, only overheated after I put some big stops into them on purpose to try it out. You'd want to go higher than 550 degrees for track days. Big old barges are hard on brakes.
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is [email protected]
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
    • Cam seals go hard. It's a very old car.
