I put some money into some shares a month or so ago. Just before it crashed....LOL
I like going into spec shares which is a gamble anyway. Fun none the less
its doing ok again now though next crash tip in some more :thumbsup:
Time to fix hail damaged bonnet on the 33...what do wasteland?
- carbon fiber bonnet (rest of car is silver) ~$800
- fill/prime, respray and hope for a good colour match (front bar really needs a respray too) ~$300
- buy second hand bonnet with no dents and respray (as above) ~$400
- paintless dent removal (existing paint is in good condition) ~$11ty
Money not an issue, I'll go with the CF if it looks good...I do like flush colours though. Do series 2 R33 bonnets fit a 1.5?
no s2 dont fit and fk no to cf bonnet ricer boy.
10k as is sit now or I'm assuming minus all goodies?
id like more but likely as it sits
Only issue with finding a silver bonnet and putting that on is that a good deal of my car has been resprayed a couple of times so I don't think the standard silver will match well, assuming the bonnet I find has perfectly good paint on it. I'd rather spend a few hundred on trying to match it / refreshing the paint. That and I could be waiting forever if it's a series 1 bonnet that I need. But a good suggestion nonetheless.
CF doesn't look too bad on this GTR...
what gtr ?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
