Just make sure you don't get too aggressive. Too often on cruises you see guys who'd have the "backyard roll" done and the paint is stressed, there is unevenness in the guard... Nasty stuff all for the sake of saving a couple bucks and spending a bit more time on it.
Nah not keen on fucking up the guards, just wanna tuck the inner lp under so there's no chance of it catching.
car doesn't start....
I took out the battery and tray to fit my fan shroud, and when i put it all back together. i have no electricity at all, battery is fine. 13V across, so what could be the issue? Obviously, car won't start. Grounding?
Three new Audi A8s driving one in front of the other with their curved LED strips on...that's no coincidence...wonder where they were headed? Towards Ferntree Gully? :/
Audi A8 uses individual LED's for the main driver headlights. Probably the next craze to be copied by all other car manufacturers.
Props for Audi to create something even cooler than the led strip they made in the past
massive traffic at boronia rd/stud road intersection. Saw a tow truck fly up to the front. As I got to the front of the intersection, saw the tow truck loading up a car with a couple of police cars on the right lane. In between the cop car and tow truck was a person talking to a huge video camera...probably for the tv show HWY Patrol... Pretty silly to be causing so much traffic for a tv show :/
/CSB ; look out for a black r32 driving behind the person being interviewed on camera haha
pretty sure lexus had the led headlights on the LS range a few years back.. so audi kinda copied them if thats the case. having said that audi LED's look so good
but im so over fgts putting leds if your car dont have em dont stick them on! and now you can buy aftermarket VE holden headlights with 'audi style' LED strip what da ferk yo holden aint no audi bogan.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
