just bought a exhaust for my bike, $125 delivered from the US haha.. gonna be loud as f**k
same as in this vid, gotta skip to 1:00 for it to be on, got cut off today by some bitch in a SUV hopefully they hear me coming next time..
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
