yeh your right, cant wait for my next holiday so i can post on the internet all the way though it will be like totally so awesome.
no nerve brah.
i seen you, i know why your single ain't your fault man pretty sure they didn't drop you intentionally.
Thats hilarious shit right there... you sound emotionally disturbed by what i have said lol
Lets talk it out brah, i can be very accommodating to people with depressive/demoralized feelings, if you can stealthily avoid any ridicule from me lol
In for shisha. There's a place in St Kilda that's got a private courtyard and some good shisha. Otherwise there's always that The land of goat sphincter rings joint on Lygon st.
Erm... it's a Lebo/Arab joint.
That shisha thing isnt a The land of goat sphincter rings custom
lol i don't give two farks about ya, like seriously i wouldn't piss on ya if you were on fire.
If you're spending money on your girl.. you're doing something wrong. Get a independent women who can take care of her self.
you spend hundreds/thousands on your car but wont spend money on your girl?
yes you get an independent women who can take care of herself when she's by herself, you're a man for a reason...
another mrs? You're moving through em lol
asian women dig the muztek
Pouring down here. Clouds so dark.
fell asleep when i got home after work and woke up to the heaviest/loudest rain was f**ked
hahah
this
the owner seemed The land of goat sphincter rings to me?
call a turk an arab, and vice versa. sit back and watch the lulz
ok gaiz, saturday or friday?
bring your wimmens so they can have a bitch fit etc together
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
