yeh your right, cant wait for my next holiday so i can post on the internet all the way though it will be like totally so awesome.
no nerve brah.
i seen you, i know why your single ain't your fault man pretty sure they didn't drop you intentionally.
Thats hilarious shit right there... you sound emotionally disturbed by what i have said lol
Lets talk it out brah, i can be very accommodating to people with depressive/demoralized feelings, if you can stealthily avoid any ridicule from me lol
In for shisha. There's a place in St Kilda that's got a private courtyard and some good shisha. Otherwise there's always that The land of goat sphincter rings joint on Lygon st.
Erm... it's a Lebo/Arab joint.
That shisha thing isnt a The land of goat sphincter rings custom
lol i don't give two farks about ya, like seriously i wouldn't piss on ya if you were on fire.
If you're spending money on your girl.. you're doing something wrong. Get a independent women who can take care of her self.
you spend hundreds/thousands on your car but wont spend money on your girl?
yes you get an independent women who can take care of herself when she's by herself, you're a man for a reason...
another mrs? You're moving through em lol
asian women dig the muztek
Pouring down here. Clouds so dark.
fell asleep when i got home after work and woke up to the heaviest/loudest rain was f**ked
hahah
this
the owner seemed The land of goat sphincter rings to me?
call a turk an arab, and vice versa. sit back and watch the lulz
ok gaiz, saturday or friday?
bring your wimmens so they can have a bitch fit etc together
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
