The server I was mod on used to have an in-game mod menu so you didn't have to type commands...just push numbers and cycle through the menus. Could do cool shit like set specific players on fire etc. I played on a laptop lol. I'll put together a night for us all when I cbf.
Yeah I think the servers I was on had that as well, but not initially...
I'd be keen, never played a game on this laptop but it does have a 1gb graphics card so in theory it should handle CS, unless they've dramatically upgraded the graphics since I played...I don't have the game itself any more though so that would require some effort...
Yeah, amxmodmenu lol.
Mustafa's kebabs were good...The T urkish bread pizza was tasty too
Orly? Could of had one of these late sat night. Haha.
Young sales assistant at Nando's made it worth going there. Terrible food though.
This. I still wanna know how old she is! LOL. 14-18. Hmm
Dont matter..
Same color. You don't see red Sky's around
just drove past a red 34 on sydney rd lol
Aiight well if you wanna PM me your dream I'll have a shot lol. I've looked into that shit before, I don't believe any of it, but it's interesting nonetheless.
i'll pm you later tonight. be prepared though, freaky shit :ph34r:
Who's a GTR expert here?
Trying to help a friend replace his leaking stock R32 GTR injectors.
Can anyone confirm if the below information is correct? He has no after market ECU at the moment so fitting a bigger injector would probably mean his car won't run so his looking for a stock replacement atm.
Its going to be hard to find a direct stock replacement.
You are better off picking up some larger denso/sard injectors off ebay (which are low imp) and buy a nistune board for his ecu.
I picked up some Sard 550cc GTR injectors for like $500. Throw in another $200 for the nistune board. $700 all up and opened the door for future tuning :)
Ah yes, yes, these R32's are bit like pets...
PM me the name of seller/workshop. The message sounded like some knob selling stuff on eBay.
im preparing for the moment when I have to put the ol' girl down haha
Its blind and only has 3 legs atm :P
Wonder if guys on here will still be driving Skylines by then lol
I think I'll still driving in Skylines whether it's same or different.
Having 7 of them and I think I can't stay away from them...
That is why I've seen the light and bought a R33...
Aww shepparton had a noodle box. Could of gone there at nats to get some :[ Would of been better than their crappy nandos.
We went there Fri night shoulda said something!
I was all about counterstrike. Haha. Almost made to top of WCG Aus.
@taxreturn, umm... yeah of course! :nyaanyaa::ph34r:
cs old school. Last time i played there was some zombiehorde mod. Good fun.
Needs CS lan + beerz.
Which server you running?
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
