Its going to be hard to find a direct stock replacement.
You are better off picking up some larger denso/sard injectors off ebay (which are low imp) and buy a nistune board for his ecu.
I picked up some Sard 550cc GTR injectors for like $500. Throw in another $200 for the nistune board. $700 all up and opened the door for future tuning :)
His got a power fc at the moment but not yet installed. I told him to fit some ID1000/Bosch injectors as he will be looking for big power down the track.
Money is the issue at the moment, but I say do it once do it right.
Sell the PowerFC and use it to pay for injectors + nistune.
You guys should chat, his name is Justin from the beach cruise and AGM if you remember.
How come you went the Sard's and not the ID/Bosch injectors as they are only about $100 per injector?
You say it wrong bruvva... gotta say: do it phaggot.
ah yeah i remember. With the clean r32 GTR.
SARD's were the cheapest on ebay at the time, reputable brand and it was a direct replacement for GTR. (i had gtr stock injectors wired in which failed, so easier to replace with sard gtr's)
It's also good to replace the injector plugs as they will no doubt be coroded/rusted. Mine were green, no idea how any voltage went through it...
I failed E*P*A because the inspector told me my injectors should be red and not purple, so whatever he gets make sure to paint them to stock colour. However, he wont pass EPA with a powerfc whereas with a nistune and tuned to pass emissions will ;)
Used to dominate zombie horde! 200-3 and shit...
Mad fun playing the zombies, humans didn't stand a chance against zombie me, people actually stopped playing on the server :D
I'll pass it on to him :thumbsup:
I was going to get 550's in and hop around with that for a while untill I get the power fc in and tuned. Now im just thinking I'll get the 750's slap em in got new pod filters waiting to go in, get a adjustable FPR and I'll put my power fc in and change oils untill I can get it booked in for a tune and most likely strap it to the back or a trailer and tow it down.i dears??
Me and a coworker just smashed Nandos $21 full chicken, seriously large chips and 1.5L coke meal for 7th consecutive day.
I think I'm gonna start sweating hot & bbq sauce.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
