So she realized in a bar full of people that your a gamer.. Safe to say your not as cool as you thought you were.
But hey a good looking chick is a good looking chick
lol thanks for the downside. If it's because I didn't have skin tight jeans on and a bad hair cut that looks like I just got up, like the rest of the f**ks in the place, then I'm content with that.
mohomo
Stems from when jesska was asking me what birds looks like, me being the general mad Kunt I am, I put in a few good words in for Adam, along with a, "he's f**king chiseled. No homo"
And yeah.
Heard the factory firewall flexes and it's much worse with a super heavy duty. Can get nismo brackets on eBay, but if it's busted your actual pedal assembly it could involve more repairs than just that...
My Friday night story:
A rather pretty girl walks up to me in a bar and asks if I play Xbox. Totally catches me off guard (what the f**k is this shit Charles?), I have nothing. Confess to playing COD occasionally (more like, an hour a night), trying not to sound too nerdy. Then our ice breaker conversation revolves around how annoying campers and snipers are in MW3. She writes her gamertag in my phone and tells me to add (what happened to phone numbers?). The girl is a network admin, which explains a lot...and now I feel a little bad because, thinking about it, this is probably some IT guru's wet dream, wasted on me. Meanwhile, old mate was staring on in disbelief and has now lost his faith in humanity. Me, I'm in two mindsets: A. Lucky motherf**ker, you just picked up with the aid of a video game, how often does this happen...or B. It's a strange new world.
how many guys do you know around your age that DONT play some xbox? seems like a pretty safe line to use. this girl has stronger game than most guys i know
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
