Sucks to be at work today! Beach is awesome :nyaanyaa:
dieinafire
Birds, I'll change the rego label for you to wax my car?
Negative.
fkn lol.. scared of a short are we?
It's grounded you twat. I just want my stereo back.
LOL!
On another note, Commodore engine bay are piss easy to work on. Changing coilpacks can take me 15-30mins tops, but my brother, it took him 20 mins figuring out why the plate won't fit on his until I came and took it off and out it in the one already bolted into motor.
If you're not working and not at the beach already, then you're too crazy to join me :closedeyes:
Got a rental property to look at this arvo after work, otherwise would vato loco :P
Barbs would get there and update us on the racial demographic of the beach populace :P
Lulz, too true. Not to mention i'd get crisp burnt
Lol Birds
Also RBA have announced an interest rate cut, F*ck yeah! Now for the banks to pass it on!
Interest rates in US are at 3.5%, half of ours.
Should defiantly get down to 4.8% like it was once at. Good for borrowing, not so god for saving.
Edited by Flynnn
Customer trying to convince me that Harvey norman in thomastown quoted him below cost price for a Goldstein electric range.. Dikhead they don't do commercials.. And we're the only Goldstein reps in da north
Should have pulled the Y U LIE TO ME FOR... move on him.
http://troll.me/images/y-u-no/buttwhole-y-u-lie-to-me-thumb.jpg
you do realise the current fed rate in the usa is something like .25% ?
do you know anything about the shit you spin or what? do you realize how bad that is for there economy?
Rates dropping are a negative sign not a positive one, it means the economy is going badly rising rates mean its a strong economy..
I'm quite AWARE where we're heading hence why I'm renting :P
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
