Reminds me of the one and only time I went to a LAN party... all my nerdy mates were dominating me at CS, so I ragequit and downloaded Wolfenstein... shoulda seen them all huddling around my computer after that
I don't know who you are. I don't know what you want. If you are looking for ransom, I can tell you I don't have money. But what I do have are a very particular set of skills; skills I have acquired over a very long career. Skills that make me a nightmare for people like you. I will look for you, I will find you, and I will kill you.
Command & Conquer & Red Alert. Quake & Quake 2.
Wishing I had a Voodoo graphics card or 2 in SLI. Those were the days :D
On another note there is a cruise down to Arthurs Seat tomorrow meet at Box Hill organised by Zero Exhaust if anyone is interested.
I received a free legit copy of Quake 1 with the purchase of my 33.6kbps modem.
People be mirin it over their 28.8kbps modem.
Then the 56kbps modem came around and that was serious business!
I got Battlefield 3 for xmas, its just not the same as the good ol' days... :(
There'll be a 35R there. I waned to go.. Fkn Sydney is so boring
I remember having 'freenet' or something like that back in the quake team fortress and early CS days...
Was 100% free 56k internet, only condition was a small banner that stayed open, but was hidden when playing quake/cs etc.
Used to lose it when I had to d/c for someone to make a phone call though lol
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
