Enter this http://www.skylinesaustralia.com/forums/topic/387545-sau-forum-battle-come-one-come-all/
You get a 3 day pass. So basically only costs you $45 for the three days...
The entry ticket is almost $70 for a three day.
Aaron you should be entering as well.
My car is nowhere near where I would like it to be to enter that haha needs a new fuel pump to start.... I have a list of items that would need fixing. It's a shame I don't start my job till Feb 1st, would love to be getting paid already.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
