ahah :P i can understand that!
she can buy it if she wants! its for sale!
Told her about the sale bit... Don't think she wants a car that can break her hips!
Picked up new turbo...and so begins my quest for teh power and teh E-flex. Question...install myself or pay OTR $250 to do it? Seems like an easy job but I always run into trouble and woudn't mind playing COD while someone else sweats over my engine bay.
If I'm gonna settle for something in the middle I'd just go back to the 250 ninja and learn on that, upgrade to gixxer after 6-9 months
I've sat on my mates 250 Ninja, more upright position like yours than the real deal Ninja and other supersports..
There's a nice Ninja at my work every now and then, green which isn't my style but a tough looking bike..
I'm leaning towards an all black 2009 gixxer though, not a fan of the newer gixxers, something about the front just doesn't do it for me...
Just man up and get the gixxer, I kinda wish I did now but still happy with my bike. As long as you survive first few months should be fine.
Get the manifold taken off, and change the studs whilst it's being done.
Will cost more, but likely you already have at least one crook stud in there :D
Yep good advice this, I already have new studs and genuine gaskets ready to go on at the same time. One of the nuts already free spins from memory :(
Enjoy getting any broken ones out. I had 8 in total broken. Gotten 7 of them (one is being a tight as f**k c***)
Tried drilling pilot, them 5mm drill to left hand thread drill piece (easy out)
They all came out like that (easy)
This one won't really budge. Used shitloads of rust of ice, tried hitting it with oxy. No luck. :rant:
Keen to just throw it together with the one not on. (did it on old motor for same reason and lasted 3,000km (till motor blew) but thats not good enough. Want to do it properly.
There is my rant anyhow.
I'm full of it :D
And ye - Thread Doctor - he is a "come to you" guy, does it on the spot.
Cheap as well which is awesome considering how much of a headfcuk of a job it is to do if you dont have the tools.
Even most workshops just call him lol
Got new sway bar links cos one of them was clean snapped, spent 1hr trying to fit just one side to the hardest setting on my sway bar with no luck... Surely there is an easier way? Anyone know any tricks? Used the trolley jack pole to move the sway bar and still nothing....
Sway bar links are whiteline, incase anyone was wondering
Likelihood of getting pulled over though? (When not riding like a Flynn)
You will get done for riding on a large bike while on your restrictions if:
1. By chance you are pulled over for a check perhaps for something else and they realise
2. They drive behind you, check the rego and note that the registered owner is not licensed to ride the bike. This can be avoided by getting someone else to register the bike in their name if you can convince them
3. You crash the bike. Insurance won't pay out if you're not licensed and I count that as 'doing yourself'
I've know multiple people who have been caught while riding on their restrictions or who have written off bikes while on them
i see.
put fake rego plates on and do a runner if you get pulled over :whistling:
but you'll most likely crash it since your still learning on it...
Lol exactly, I found the time on my 250 was priceless... Although I think I was a special case. Getting your knee down on the Black Spur on a 250 that is the sloppiest bike in the world isn't what most learners will be doing.
I'd recommend just dealing with a less powerful bike for max 15 months. It will do great things for your skills and you don't have to look over your shoulder. Once you're off them it's like it never happened.
can't you weld a nut on it and go from there ? then again if easy out didn't work i don't think anything will
Havn't done much welding and the studs 'tend' to snap approx 2 threads INTO the head so I don't know how u would go welding onto them with minimal space and surface area.
Ended up getting the last one so all good. :banana:
Edited by bluey33
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
