ahah :P i can understand that!
she can buy it if she wants! its for sale!
Told her about the sale bit... Don't think she wants a car that can break her hips!
Picked up new turbo...and so begins my quest for teh power and teh E-flex. Question...install myself or pay OTR $250 to do it? Seems like an easy job but I always run into trouble and woudn't mind playing COD while someone else sweats over my engine bay.
If I'm gonna settle for something in the middle I'd just go back to the 250 ninja and learn on that, upgrade to gixxer after 6-9 months
I've sat on my mates 250 Ninja, more upright position like yours than the real deal Ninja and other supersports..
There's a nice Ninja at my work every now and then, green which isn't my style but a tough looking bike..
I'm leaning towards an all black 2009 gixxer though, not a fan of the newer gixxers, something about the front just doesn't do it for me...
Just man up and get the gixxer, I kinda wish I did now but still happy with my bike. As long as you survive first few months should be fine.
Get the manifold taken off, and change the studs whilst it's being done.
Will cost more, but likely you already have at least one crook stud in there :D
Yep good advice this, I already have new studs and genuine gaskets ready to go on at the same time. One of the nuts already free spins from memory :(
Enjoy getting any broken ones out. I had 8 in total broken. Gotten 7 of them (one is being a tight as f**k c***)
Tried drilling pilot, them 5mm drill to left hand thread drill piece (easy out)
They all came out like that (easy)
This one won't really budge. Used shitloads of rust of ice, tried hitting it with oxy. No luck. :rant:
Keen to just throw it together with the one not on. (did it on old motor for same reason and lasted 3,000km (till motor blew) but thats not good enough. Want to do it properly.
There is my rant anyhow.
I'm full of it :D
And ye - Thread Doctor - he is a "come to you" guy, does it on the spot.
Cheap as well which is awesome considering how much of a headfcuk of a job it is to do if you dont have the tools.
Even most workshops just call him lol
Got new sway bar links cos one of them was clean snapped, spent 1hr trying to fit just one side to the hardest setting on my sway bar with no luck... Surely there is an easier way? Anyone know any tricks? Used the trolley jack pole to move the sway bar and still nothing....
Sway bar links are whiteline, incase anyone was wondering
Likelihood of getting pulled over though? (When not riding like a Flynn)
You will get done for riding on a large bike while on your restrictions if:
1. By chance you are pulled over for a check perhaps for something else and they realise
2. They drive behind you, check the rego and note that the registered owner is not licensed to ride the bike. This can be avoided by getting someone else to register the bike in their name if you can convince them
3. You crash the bike. Insurance won't pay out if you're not licensed and I count that as 'doing yourself'
I've know multiple people who have been caught while riding on their restrictions or who have written off bikes while on them
i see.
put fake rego plates on and do a runner if you get pulled over :whistling:
but you'll most likely crash it since your still learning on it...
Lol exactly, I found the time on my 250 was priceless... Although I think I was a special case. Getting your knee down on the Black Spur on a 250 that is the sloppiest bike in the world isn't what most learners will be doing.
I'd recommend just dealing with a less powerful bike for max 15 months. It will do great things for your skills and you don't have to look over your shoulder. Once you're off them it's like it never happened.
can't you weld a nut on it and go from there ? then again if easy out didn't work i don't think anything will
Havn't done much welding and the studs 'tend' to snap approx 2 threads INTO the head so I don't know how u would go welding onto them with minimal space and surface area.
Ended up getting the last one so all good. :banana:
Edited by bluey33
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
