ahah :P i can understand that!
she can buy it if she wants! its for sale!
Told her about the sale bit... Don't think she wants a car that can break her hips!
Picked up new turbo...and so begins my quest for teh power and teh E-flex. Question...install myself or pay OTR $250 to do it? Seems like an easy job but I always run into trouble and woudn't mind playing COD while someone else sweats over my engine bay.
If I'm gonna settle for something in the middle I'd just go back to the 250 ninja and learn on that, upgrade to gixxer after 6-9 months
I've sat on my mates 250 Ninja, more upright position like yours than the real deal Ninja and other supersports..
There's a nice Ninja at my work every now and then, green which isn't my style but a tough looking bike..
I'm leaning towards an all black 2009 gixxer though, not a fan of the newer gixxers, something about the front just doesn't do it for me...
Just man up and get the gixxer, I kinda wish I did now but still happy with my bike. As long as you survive first few months should be fine.
Get the manifold taken off, and change the studs whilst it's being done.
Will cost more, but likely you already have at least one crook stud in there :D
Yep good advice this, I already have new studs and genuine gaskets ready to go on at the same time. One of the nuts already free spins from memory :(
Enjoy getting any broken ones out. I had 8 in total broken. Gotten 7 of them (one is being a tight as f**k c***)
Tried drilling pilot, them 5mm drill to left hand thread drill piece (easy out)
They all came out like that (easy)
This one won't really budge. Used shitloads of rust of ice, tried hitting it with oxy. No luck. :rant:
Keen to just throw it together with the one not on. (did it on old motor for same reason and lasted 3,000km (till motor blew) but thats not good enough. Want to do it properly.
There is my rant anyhow.
I'm full of it :D
And ye - Thread Doctor - he is a "come to you" guy, does it on the spot.
Cheap as well which is awesome considering how much of a headfcuk of a job it is to do if you dont have the tools.
Even most workshops just call him lol
Got new sway bar links cos one of them was clean snapped, spent 1hr trying to fit just one side to the hardest setting on my sway bar with no luck... Surely there is an easier way? Anyone know any tricks? Used the trolley jack pole to move the sway bar and still nothing....
Sway bar links are whiteline, incase anyone was wondering
Likelihood of getting pulled over though? (When not riding like a Flynn)
You will get done for riding on a large bike while on your restrictions if:
1. By chance you are pulled over for a check perhaps for something else and they realise
2. They drive behind you, check the rego and note that the registered owner is not licensed to ride the bike. This can be avoided by getting someone else to register the bike in their name if you can convince them
3. You crash the bike. Insurance won't pay out if you're not licensed and I count that as 'doing yourself'
I've know multiple people who have been caught while riding on their restrictions or who have written off bikes while on them
i see.
put fake rego plates on and do a runner if you get pulled over :whistling:
but you'll most likely crash it since your still learning on it...
Lol exactly, I found the time on my 250 was priceless... Although I think I was a special case. Getting your knee down on the Black Spur on a 250 that is the sloppiest bike in the world isn't what most learners will be doing.
I'd recommend just dealing with a less powerful bike for max 15 months. It will do great things for your skills and you don't have to look over your shoulder. Once you're off them it's like it never happened.
can't you weld a nut on it and go from there ? then again if easy out didn't work i don't think anything will
Havn't done much welding and the studs 'tend' to snap approx 2 threads INTO the head so I don't know how u would go welding onto them with minimal space and surface area.
Ended up getting the last one so all good. :banana:
Edited by bluey33
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
