There will be a small window next Saturday between say 5-7p.m where ill be at my parents in Vermont South to go to a wedding with my brother.
If your free then let me know.
Next saturday as in 11th?
If so, I'll be mostly free unless for some reason I'm being kidnapped or whatever...
Nah it's a weekender, I wouldn't even do 10,000km in a year I don't think
pads are still too harsh if you aren't doing trackwork. they wont work well enough cold to merit the disk destroying nature of them.
for a weekend car ebc redstuff is probably a better choice
Sooo can you run two sets of pads? do the discs respond well?
not really... redstuff is easily good enough for a weekend warrior....
fwiw i run them and they do fine
Why can't girls just get along?
6 years at working at the same place and there has always been a tensions/girls not get along/bitching between different sets of girls.
This also applies to girls that I'm friends with too.
All the work guys always get along and also the group of guys outside of work have never had a qualm.
Feel like I'm Dr Phil when girls are breaking down in my office.
Just sit their and listen but you can't touch! A manager has been sued before for trying to comfort a crying employee :/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
