There will be a small window next Saturday between say 5-7p.m where ill be at my parents in Vermont South to go to a wedding with my brother.
If your free then let me know.
Next saturday as in 11th?
If so, I'll be mostly free unless for some reason I'm being kidnapped or whatever...
Nah it's a weekender, I wouldn't even do 10,000km in a year I don't think
pads are still too harsh if you aren't doing trackwork. they wont work well enough cold to merit the disk destroying nature of them.
for a weekend car ebc redstuff is probably a better choice
Sooo can you run two sets of pads? do the discs respond well?
not really... redstuff is easily good enough for a weekend warrior....
fwiw i run them and they do fine
Why can't girls just get along?
6 years at working at the same place and there has always been a tensions/girls not get along/bitching between different sets of girls.
This also applies to girls that I'm friends with too.
All the work guys always get along and also the group of guys outside of work have never had a qualm.
Feel like I'm Dr Phil when girls are breaking down in my office.
Just sit their and listen but you can't touch! A manager has been sued before for trying to comfort a crying employee :/
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
