There will be a small window next Saturday between say 5-7p.m where ill be at my parents in Vermont South to go to a wedding with my brother.
If your free then let me know.
Next saturday as in 11th?
If so, I'll be mostly free unless for some reason I'm being kidnapped or whatever...
Nah it's a weekender, I wouldn't even do 10,000km in a year I don't think
pads are still too harsh if you aren't doing trackwork. they wont work well enough cold to merit the disk destroying nature of them.
for a weekend car ebc redstuff is probably a better choice
Sooo can you run two sets of pads? do the discs respond well?
not really... redstuff is easily good enough for a weekend warrior....
fwiw i run them and they do fine
Why can't girls just get along?
6 years at working at the same place and there has always been a tensions/girls not get along/bitching between different sets of girls.
This also applies to girls that I'm friends with too.
All the work guys always get along and also the group of guys outside of work have never had a qualm.
Feel like I'm Dr Phil when girls are breaking down in my office.
Just sit their and listen but you can't touch! A manager has been sued before for trying to comfort a crying employee :/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
