Why can't girls just get along?
6 years at working at the same place and there has always been a tensions/girls not get along/bitching between different sets of girls.
This also applies to girls that I'm friends with too.
All the work guys always get along and also the group of guys outside of work have never had a qualm.
Feel like I'm Dr Phil when girls are breaking down in my office.
Just sit their and listen but you can't touch! A manager has been sued before for trying to comfort a crying employee :/
thats seriously dumb!
human nature is to comfort someone when they are crying..
getting sued for it is pathetic!
Show him your roof :P
carbon fibre shtickerrrr!
Mirror finish :P
:thumbsup:
Hmmm well I have the a1rm sitting there atm so I might get them put in for the time being. Look into red stuff when I get a chance.
not a valid reason to chew through the DBA's.
QFM HPX's are like $80 a pair
Yup a manager got taken to court for comforting a staff member after she was crying. I.e. rubs on the back and a hug.
Case was dismissed in court, but having that mark against your name and months of stress wasn't good for the manager.
So I just sit back and hand them tissues :D
And yes bitches b crazy
And that there is one of the reasons people aren't as nice to each other anymore...you can get sued for being nice and errr...crims with bad intentions get off pretty easily :/
I remember some guy saying how he can't even look at or say hi to people's kids at the supermarket anymore, for fear of being thought of as a creep/pedophile...can relate to this. The times, they are a changin'.
That said, can't wait to get stuck into the ladies at my new job lol
Sexual harassment at a...legal firm? You got balls :P
i have my gtst going in for a rwc tomorrow morning - he keeps telling me my return flow fmic will need to come off..
just wondering if anyone knows where can i find documentation which shows its legal?
I've only been able to find it on the EPA information bulletin
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
