I agree Dez
People who actually believe that shit.
I say go commit a crime, use that argument.
Let me know when the court date is so I can come for the lulz
lol would be f**kin awesome to watch some cunt get locked up for some bad shit coz he thought he could pull this..
That Josh guy is a classic...even IF this bullshit was true, I guarantee the cop wouldn't have a f**king clue about it and there is no way in hell he'd drive away from being pulled over at 160km/h
Bunch of shit fallers and despos on there some ugly chick posts up some random shot 1000 comments later they still trying to get there end off.. Few of us took the piss out of the loser the other night for trololols
tell him to show you where it says that a return flow front mount is illegal (as long as you don't have a pod)
failing that, call him a cocksucker
One intake modification is allowed, you can have Reverse-flow FMIC assuming you still have standard airbox.
Failing that, do what Dezz said.
yeah i have only the blitz return flow/reverse flow fmic.. and i chose that one due to it being legal.
i am running standard airbox also..
coilovers i have tein monoflex and cant put standard ones back in because the rears were both gone within the first few months after buying the car..
so i guess ill either be telling him he is a 'cocksucker' or ill talk my way through a rwc
Ahahgahahahahhahahahah
Ohhhhhh alexxxxx <3 no homo
It's true though, about the FB stuff at least. It seriously hurts my eyes, and brain. Least it keeps it off the forums, means less work for me.
Mmm will depend if im catching up with a lady or not.
However unlikely regardless I think... Mt Baw Baw sprint is on the w/e after. Really cannot afford to put that in jeapordy as it's going to be farken nuts!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
