friend at my work has a 2002 vvti turbo supra, 18000km on the dial with plastic still on the rear seats!
Was an importer back in the early 2000's...
Dead stock, I wonder if it would be worth more than a GTR in the same condition?
Yeh I'm not up with technology so fkd if I know how to turn shit off/ unfollow
Man fpv pricing is all over the place an f6 a gs315 and an ex demo 335 are all with a grand or two of each other what the?
Moh just ziptie it out the way
I dunno man 24gb of RAM and a xeon x5660 not sure how much more power I need.
Hah!
Your files exceed the limits of the PC power...
Need more power for PC...
I'm a big fan of project mu b spec pads - spoke to there head office in qld that night at about 7pm had then the next morning at about 11:30am, was incredibly fast!
I am running a set of Project MU front pads and are great.
i should hey, thats what i did last time but hit pothole and the tyre f**ked everything up.
ill pop the guard off tonight and sus it out.
hey mohsen I need some chop sticks and can you make me a kebab.
you gay boy
Kris' brother and that Josh cocksucker think they're pretty tough...
Haha my brother doesn't think hes tough. He knows he is. Has sent 5+ people to hospital. He knows how to fight. He doesn't just talk about beating c unts up. He actually does.
Haha my brother doesn't think hes tough. He knows he is. Has sent 5+ people to hospital. He knows how to fight. He doesn't just talk about beating dream boats up. He actually does.
hahaha
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
