friend at my work has a 2002 vvti turbo supra, 18000km on the dial with plastic still on the rear seats!
Was an importer back in the early 2000's...
Dead stock, I wonder if it would be worth more than a GTR in the same condition?
Yeh I'm not up with technology so fkd if I know how to turn shit off/ unfollow
Man fpv pricing is all over the place an f6 a gs315 and an ex demo 335 are all with a grand or two of each other what the?
Moh just ziptie it out the way
I dunno man 24gb of RAM and a xeon x5660 not sure how much more power I need.
Hah!
Your files exceed the limits of the PC power...
Need more power for PC...
I'm a big fan of project mu b spec pads - spoke to there head office in qld that night at about 7pm had then the next morning at about 11:30am, was incredibly fast!
I am running a set of Project MU front pads and are great.
i should hey, thats what i did last time but hit pothole and the tyre f**ked everything up.
ill pop the guard off tonight and sus it out.
hey mohsen I need some chop sticks and can you make me a kebab.
you gay boy
Kris' brother and that Josh cocksucker think they're pretty tough...
Haha my brother doesn't think hes tough. He knows he is. Has sent 5+ people to hospital. He knows how to fight. He doesn't just talk about beating c unts up. He actually does.
Haha my brother doesn't think hes tough. He knows he is. Has sent 5+ people to hospital. He knows how to fight. He doesn't just talk about beating dream boats up. He actually does.
hahaha
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
