lol i linked it coz it looks good not coz its the fastest learner legal bike! not really interested in speed at this stage, dont wanna die just yet lol
Ah okay, meh...9k for the looks is a bit :/
Kawasaki have like 11ty different models of 250cc bikes, should be able to find a Jap 250 you like the look of.
Aftermarket kit by Tyga, stock looks like this. Also available for other models
Had a f1 sounding late 80's bike pass by the other day, sweeeet
Is anyone a really experienced in electrical stuff with installing gauges. A very experienced auto elec spent all day trying to get my autogauge gauges to work but in his opinion all 3 are faulty.
Had no problems wiring my mates ones on the same day. His gauges are a different type so couldnt interchange to test.
Will pay monies if anyone can fix it ASAP otherwise I'll just email just jap Monday morning to discuss the issue :(
My dad owns and runs an electronics repair business for 30yrs. Can have a look at it. Let me know it free tomorrow we can have a play around with it. In dandenong. Pm me for more info
Hamish I didn't go to the dyno day I went to cihan for a tune.. The cars timing was out by 10 degrees I'm suprised I didn't break something..
I'm running a Hks gtrs or whatever they're called runs like a dream now..
Only thing is there are custom wade cams are massive, so the mid range is abit flat. I think the motor was built for a massive turbo
That's pretty responsive for a gtrs on a 2L isn't it? Must be good fun now!
hmm seems a little low for a gt-rs.
I would expect closer to 250, what supporting mods do you ahve for it
PM sent! :thumbsup:
Did u get the stepper motor ones?
You have to wire active (red) and one of the colour (orange or white)to positive and black to ground. The orange and white is the colour of the lights.
Ya the purple s14 with CAMS and GTRS made approx 250 on chasers dyno today.
But i think aaron runs the standard airbox?!?!?
Hey John,
Yeah I got the Autogauge Shadow Pro series. Stepper Motor Series.
Red is wired to constant power. Orange to accessories, yellow to lights and black to ground. Everything was done by the auto electrician as per manual.
They all turn on but are not reading anything through the sensor. Also the water and boost gauge flash intermittently showing something is wrong.
But everything has been wired correct and checked by two seperate people :/
Have wasted a whole day on this....
Hey John,
Ah I didn't try em that way.
Wired both into accessories. Off the back of the sig lighter.
Josh did the same with his 32 iirc
That is the stepper motor series tho
Yeah my mate bought the autogauge stepper series and installed without a problem today :(
Though he wasn't sure where you put the aftermarket oil sensor.
Where did you put yours? Any fiddling around?
pretty sure you screw your oil filter onto a sandwich plate which you connect your oil pressure/temp sensors to. no?
mmm very nice!
Edited by R-SPEC
yeh it is but ill explain below why
its a GTRS high flowed into an s15 compressor housing.. so its not up there at 250 flow wise, but its a hell of a lot more responsive than it usually is.. Cihan said there was definitely more power he could get out of it, but i didnt want to push it.. im happy with 230kw in a car that weighs half as much as the stag lol
yeh sort of. i have the bottom of the airbox shaved off though.
i wouldnt mind chucking it on another dyno to see if there is a differing figure.
mmm very nice!
Cheers Rimon
On the topic of bikes. There was a pack of bikes on princess hwy frday night doing wheeles & burnouts @ 100km/h..... :mellow:
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
