Keep both is doable?
It may be doable, the biggest problem I have is I live at the top of a court in which there is a double garage and we shuffle cars around already, not a big fan of leaving a car out in the court either
Wow...what is it about the GTS-T that gave you second thoughts about selling, when comparing it to the GTR?
+ 1
Since your driving both cars atm, how do the two compare back to back etc..
I'd assume there making similar power as well
ive always been so persistent on the gtst handling really well, the steering is very light compared to the gtr
the gtr is stock apart from exhaust, coilovers, wheels etc - the gtst is pretty much all braking and handling mods with exhaust and a few other things fmic etc
im guessing the monoflex coilovers in the gtst are one thing which really make me enjoy it and having hicas lock bar makes it more predictable
the gtst feels alot lighter to drive and feels very agile but it doesn't feel as refined as the gtr in anyway
yeah i guess the power wouldnt be too much different but the gtr is still ahead im sure of that - the rb25 feels as though boost comes on faster (probably due to aftermarket solenoid, stock boost) but doesn't have the pull of the rb26 when that hits boost (stock)
sure you can tell the gtr is the better car in pretty much every way, but there is something about the gtst in which makes me feel happy when i drive it, which I guess in a way i didn't appreciate until I had the gtr to compare it to.. and also I don't think I would appreciate the gtr as much if I didn't drive a gtst first..
the gtr has always been my dream car (as for alot of us im sure) and still is while owning one.. incredible car to drive, look at etc
the gtst its my first skyline and it got me hooked on them (apart from watching the r32 tear up bathurst as a kid), I guess it comes down to the fact that for a daily I would love to use the gtst and have my gtr for weekends
sorry for wall of text :P
Cheers for the write up Anthony :thumbsup:
I must admit the gts-t/gtt is good as a daily. Not bad on fuel, cheap to run, easy to drive, don't really worry about parking it anywhere etc...
Keep both if you can :D
Talked to Matt last night, he said why the hell did I encourage you to keep the GTST...
lol :rofl2: well at the moment I haven't decided!
Its still for sale at this moment but who knows what I will decide over the next few days lol
Nothing better than waking up to your delivery from Tomei! :D
Came with complementary Japanese newspapers too lol
Not sure who it was but I did see someone post up parts of the wrapping with his package fkn Japan and it was tentacle rape shit or something LMAO
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
