dude trust me in saying dont get a cbr250rr, ignoring the age / import / what ever.
you're a bit dude and they are TINY bikes, will A. Not be comfy B. look retarded. and C. doing freeway driving on those will be revving the tits off it.
my 2c anyway
at least take one for a decent ride then take say a ninja 650r for a spin as well to see difference
lol birds just overtook me on flynns hit list, no doubt he has one like the guy in billy Madison
Player status revoked bird mang
Ps car not sold Stayin put... Foreverr
How come not sold it?
RWC too much of a hassle?
Yeh pretty much grant it could be done but for what I'm selling it for compared to cost of items to get rwc it's pointless since I don't have to sell it and im not hard up for funds so just keep it and worry about it if I'm ever in need of $$
More track time is planned fo sho!
While we are talking about bikes....I'm going for my bike L's in a few weeks :)
Been looking at a white Ducati 1198S. The colour scheme is basically the same as my car.
Saw one at the servo last night. He caught me mirin
Sale fall through or decided against selling?
EDIT: Just saw reasons above.
Was looking at a Streetfighter S the other day and saw this for quite a bit less $
_M3S7647.jpg?g2_GALLERYSID=TMP_SESSION_ID_DI_NOISSES_PMT
Evooooooo. Rode one, same colour but black rims, on the Sepang circuit.... it was pretty delish, even just as an 848 all the V's have so much low down torque = plenty of fun.
That looks quite good with the red.
The 1198 I saw had carbon Termi exhaust and extractors. Bike still had 2 years warranty as well. I think it sold though.
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
