yep repairable writeoff from hailstorm
the car is at pickles auctions
Not sure on the actual process involved but you could just buy it back for cheap and then drive it?
Sounds like win, get a cash payout and keep car. What's a few dents anyway :D
yep when your car is written off, at least in hail damage you get the option to buy the car back
you get two options
option 1 - loose car and they pay out the policy value, agreed or market depending on what you selected
option 2 - you keep the car and they pay out policy value minus the cars new damaged value
in my case, whilst the damaged value was low, it still wasnt low enough to be useful given the car had so many km's on it and general wear and tear
the agreed value was pretty high considering the car (97 gtst with 250k on the clock) so it was much more worthwhile for me to loose the car.
if i kept the car i would have been stuck with it full of dints and basically unsellable (it was almost unsellable before the hail dmg) so happy to a chance to get rid of it.
i get a chance to get a new normal car (non 2-door and non-loud car) and play with a better car after married and some work on the house.
yeah i wasnt out to gouge the market
besides it was previously repaired so its not "as new" but still working 100%
i was happy with 700 and to see it gone
as long as the other parts sell off ill be v happy
the boost kit should go for sure
the rsm will
the vafc is a bit unsure
and the turbo timer wil
all the auctions i put were the minimum id happily take
so if i get 1 bid im happy
i dont believe in starting auctions at mega low prices to try and entice people
just start it at the minimum you would accept and let it go
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
