yep repairable writeoff from hailstorm
the car is at pickles auctions
Not sure on the actual process involved but you could just buy it back for cheap and then drive it?
Sounds like win, get a cash payout and keep car. What's a few dents anyway :D
yep when your car is written off, at least in hail damage you get the option to buy the car back
you get two options
option 1 - loose car and they pay out the policy value, agreed or market depending on what you selected
option 2 - you keep the car and they pay out policy value minus the cars new damaged value
in my case, whilst the damaged value was low, it still wasnt low enough to be useful given the car had so many km's on it and general wear and tear
the agreed value was pretty high considering the car (97 gtst with 250k on the clock) so it was much more worthwhile for me to loose the car.
if i kept the car i would have been stuck with it full of dints and basically unsellable (it was almost unsellable before the hail dmg) so happy to a chance to get rid of it.
i get a chance to get a new normal car (non 2-door and non-loud car) and play with a better car after married and some work on the house.
yeah i wasnt out to gouge the market
besides it was previously repaired so its not "as new" but still working 100%
i was happy with 700 and to see it gone
as long as the other parts sell off ill be v happy
the boost kit should go for sure
the rsm will
the vafc is a bit unsure
and the turbo timer wil
all the auctions i put were the minimum id happily take
so if i get 1 bid im happy
i dont believe in starting auctions at mega low prices to try and entice people
just start it at the minimum you would accept and let it go
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
