And on top of that, I know Of the perfect hks 2535 setup for sale, with manifold, ex gate, and stock heatshield incl covers the whole setup.
Hmmmm... Pm me NIGGAHHHH
Goal of the build is a nice cruiser with balls.. Gonna be stripping the interior tonight.
1329694616[/url]' post='6242686']
Pass us your Driver Dynamics Track day Aaron if you can't get your car ready in time :D
Saw the SAU Nats DVD last night, was all right :thumbsup:
Going in on Wednesday ... Should be fixed before the DD day
Just go for modest power unless you plan on putting in a larger displacement engine. Any RB20 with balls = pain in the ass to drive around town and a 5000rpm powerband, although cool for motorsport, is next to useless on the road.
Guess again...I want you to do 500-1000km of normal driving on those new bearings before you go thrashing my gearbox around a track day. The last guy who did that on a freshly reconditioned box cooked the bearings and ripped every tooth off the third gear cogs = no warranty.
http://www.heraldsun.com.au/news/more-news/wrong-way-caravan-busted-on-west-gate-bridge/story-fn7x8me2-1226274928926
Some guy this morning driving with a caravan driving onto on-comming traffic for 12kms down Westgate and Monash Fwy.....lolwut
http://www.heraldsun...2-1226274928926
I bet he gets off with no vehicle impound and will be charged with careless driving, also no loss of licence
Hmmmmm..
If I'm gonna go through the hassle of a larger engine I might as well build something good and drop it in.
Sif, they'll say that an import careened him onto the wrong side of the road and that Vicpol are looking for suspects and planning several operations to protect the people.
Do you know what the sad thing is? Reading back on this ridiculous analogy, and realising it isn't even far from the truth.
2535 is a bit of a headache but nothing wrong with a 2530 on streets with 210kw.
This wednesday right? If so, his got a good 3 weeks to do that. 1000km in 3 weeks is easy, for me anyways...
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
