This is the car i've been driving around since i've been back home. (This isn't a photo of the actual car, but it's the same model) My old lady sold this to me for cheap, it's a 5.0l Fairlane, its in really good condition and has been with us since brand new. Incredibly comfortable to drive and it's on gas.
To tint windows dark black, and lower for potential pimp car lookz?
Something like this?
Or just leave it as is, personally i'm not too fussed lol.
