You can't do 4WD helli's @ Winton.
You can @ DECA
DECA > all.
and it'll be too sore to even wipe.. bidet ftw.
I honestly never really appreciated the reason for one of these until i started eating really hot dishes.
One morning, about 4.37am, it all made perfect sense in one enlightening stroke.
I'll head up Sunday most likely workin on saturday.
I can't even eat a kfc zinger burger that's my tolerance for spicy
LOL...
yeh mohsen..
you need to buy your girlfriend her school books as well so factor that into the cost too
LOL!
I'm thinking, might as well spend an extra few months getting it all right so I don't have to do it again,
After the important things, but yeah, whatever you think.
Yeah should stil be going up, probs take will and jess too
Well my car is ready today from the panel beater and will pick it up tomorrow morning.
So you can ride passenger with me, if you want.
rides at deca > watching people drift :P
Rides in a drift car > rides with a person in a giant parking lot.
Can the plastics on r32 gtr be taken off?
Good driver seats are almost non existent. Thinking about buying a crappy one and another passenger seat and swapping everything over.
