lol I was just looking at some houses on realestate.com.au and a lot of the photos were taken with sun shining through the windows into the houses and no furniture, makes them look VERY hot to walk through, even today.
So damn cheap, someone buy it before I do something stupid:
http://www.carpoint.com.au/all-cars/private/details.aspx?R=12171585&__Qpb=1&Cr=10&__Ns=pCar_YearMade_Int32|1||pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|0&keywords=&__No=15&__N=834%201216%201246%201247%201252%201282%204294966879%204294729565%204294967079%20447&SearchAction=N&silo=1011&PriceTo=447&seot=1&__Nne=15&trecs=105&__sid=1355711DA55E
Mmmm M3's.
Last night saw Aaron's friend with the convertible E46 M3 convertible. 11 inch rims on 235 tyres :/
lol just saw that it's in QLD, looks like I won't be inspecting it on a whim. Still, anyone serious about buying one, that sounds pretty legit...cleanest I've seen for a while.
Disagree re: r32 plan
Harder and harder to find a r32 which hasn't gone down the cheap thrashed path. It is better to see a clean r32 than some cheap and nasty with power because that power is nothing spectacular so it's lose-lose.
My opinion would be to restore a r32 gtr but 4dr's provide a different view
Good luck with the rebuild, in 5-10years time when everyone has moved on to their family/boring cars you will have something which wasn't discarded because of the cheap thrash mentality.
Similar example; look at all the kingswoods being restored. Everyone looking for shells including the basic 6cyl models.
Tl;dr
Also, I just love r32s.
It's like when people do up those old rotors. They're shit. But in the end it's up to the owner.
I'm doing what I had planned for my first r32, only rwd and with a sun roof :)
Hey pat... Sunroof seal is integrated into the glass.. And they don't make them anymore. FML
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
