Who here is making over 280kw on their 25.
What is involved? Can I retain my standard gtr cooler and run a forward facing plenum to make use of the hole under the battery?
280 is a walk in the park.. GT2835 pro s / 3071 and supporting mods
All custom number plates are a rip off when people try to make money off them. The single/double/triple digits are the only ones that ever catch my eye. My grandma had 365 (on her Civic lol) and that sold for ~100k - what an idiot. Fuck spending that on a piece of aluminium.
Lower the number is supposed to signify the richer you are apparently $220k bought number 40.
Mine cost $500 and it's my name so it's good for business so people know me in the area no chance I'd pay thousands
Edited by alr33x
[HOMO] ??
Haha I kid I kid
Yeh it's set by ato I think. Just make sure you have receipts for rego/tyres/servicing etc so no backyarders basically.
Or just use credit card. :D
All car expenses to the one place, if you like to make it easy/simple.
Keep the reciepts in a box of course, but for tallying purposes, cannot go past a singular instance for ease of use.
Me. It looks completely stock to 99% of people, wouldn't have it any other way.
OTR just finished my turbo swap :D
Bill came to $450, which included replacing all exhaust manifold studs and calling out the stud doctor for broken ones. I would have spent 3-4 days on that shit, these guys are working for nothing.
Now to book a tuner!
Pussy. Did mine in a day. Never dropped so many 4-letter words though lol
ok cars booked at racepace for install: cam gears, injectors, nistune. also a dyno tune and oil, filter and plugs.
Looks like the old wallets going to cop a fair bashing
but everything should be sweeeet when it's done
PM me approximate cost if they gave you a ballpark?
Nah man, Chris recon'd like if it wasn't due for timing belt they can do it without removing it so yeah they will just do that.
Ok I see.
Yeah, go ahead with that and get done asap I'd say.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
