Who here is making over 280kw on their 25.
What is involved? Can I retain my standard gtr cooler and run a forward facing plenum to make use of the hole under the battery?
280 is a walk in the park.. GT2835 pro s / 3071 and supporting mods
All custom number plates are a rip off when people try to make money off them. The single/double/triple digits are the only ones that ever catch my eye. My grandma had 365 (on her Civic lol) and that sold for ~100k - what an idiot. Fuck spending that on a piece of aluminium.
Lower the number is supposed to signify the richer you are apparently $220k bought number 40.
Mine cost $500 and it's my name so it's good for business so people know me in the area no chance I'd pay thousands
Edited by alr33x
[HOMO] ??
Haha I kid I kid
Yeh it's set by ato I think. Just make sure you have receipts for rego/tyres/servicing etc so no backyarders basically.
Or just use credit card. :D
All car expenses to the one place, if you like to make it easy/simple.
Keep the reciepts in a box of course, but for tallying purposes, cannot go past a singular instance for ease of use.
Me. It looks completely stock to 99% of people, wouldn't have it any other way.
OTR just finished my turbo swap :D
Bill came to $450, which included replacing all exhaust manifold studs and calling out the stud doctor for broken ones. I would have spent 3-4 days on that shit, these guys are working for nothing.
Now to book a tuner!
Pussy. Did mine in a day. Never dropped so many 4-letter words though lol
ok cars booked at racepace for install: cam gears, injectors, nistune. also a dyno tune and oil, filter and plugs.
Looks like the old wallets going to cop a fair bashing
but everything should be sweeeet when it's done
PM me approximate cost if they gave you a ballpark?
Nah man, Chris recon'd like if it wasn't due for timing belt they can do it without removing it so yeah they will just do that.
Ok I see.
Yeah, go ahead with that and get done asap I'd say.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
