its a good deal compared to older/similar spec and K's hondas that are priced 2-3 times higher
it's your cash, just don't understand why you'd pay so much for an old bike with so many kms that you'll more than likely want to sell in 12 months anyway
What you mean pay so much it's the cheapest I could find lol
And yes it's not a keeper so why pay 5-6k for a new one to learn on...
So was on the way to work this morning and I noticed the United in Balwyn now has e85. Are more servos starting to sell this fuel now?
The one up the road from me is selling 100 RON...
Any good?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
