Jamie, I'm currently driving around in mum's BMW 535i
I see.
Got my car back from race pace :D they did an awesome job, hat off to them.
end figure 270rwkw
Awesome!
Now come to Garage Cafe :D
I'm saying they suck because ones getting repaired because of a pissy little pot hole.
Shoulda paid a little more and got some quality rims.
I've hit massive pot holes on 'fake rims' without issue. Quality has improved a lot in recent years.
lol no different to the majority of r32's on the roads
I like the comment that it's probably going to end up in a junkyard because it's going to cost so much... because the guy obviously had no intention of spending money on it and had no idea what he was buying... ffs
if i'm invited, i follow the azn tradition of presenting the marrying couple a red packet with cash inside.
Lol. beats getting clocks and candles as gifts.
mmm lucky envelopes are the shit
gotta do the asian tombstones for more of them :P
+1 pat. need r32 sedan interior parts or im going to get all of mine re done :(
rb30 block acquired.
how the f**k do i get that toothed plate off without it turning? :/ so fkn hard lol
need to get it on my engine stand.
Your 32 will look SHIT without some blue Rays valve caps mohomo.
i will buy them if you oil yourself up and take zyzz style pics and post them in the wasteland.
im dead serious lol. marc would get a boner.
you mean the flywheel?
ever heard of an impact gun?
ill try that tomorrow
Momo, you'll need decent clutch, something called Nismo Coppermix...
I've got one sitting in the garage waiting for proper home aka in the bellhousing and behind the block.
/plug.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
