agree
facebook is not twitter
if i wanted to read twits, i would join twitter and read them
in other news
didnt bother replacing projector (our dell one died)
not worth the $ and stuffing around
got a 50" installed on the wall for 600 so pretty reasonable
a projector would have cost me about 1200 ish
is only a small 3x3m room so 50" is actually pretty good size for the area
agree
sometimes I cbf posting the same thing on both, so I tweet and FB status update on the same thing (using Tweetdeck). You may end up with a hashtag or two. Don't like it, tune it the fuck out by unsubscribing. It's not like I have a gun to your head telling you to read that shit.
Failing that you can ignore updates from the Twitter or Tweetdeck app. That way any FB update from twitter or a twitter-centric tool won't show up in your feed.
People who post hashtags on FB without any link to twitter tho...
I need an accountant or a hook up to one that can help me maximise cash monies. My previous one just skipped the country to NZ.
PM Tony aka blah_blah on here, he's the bean counter.
Or the fact I'm only running 19psi and a 3" exhaust at the moment? :)
to those kind of people mods don't mean anything
dyno results rule all :P
Lambos are for kids
Get a brabus
brabus nice
True Alex.. can't dose the latte sippers lol :(
I've got a thing for Italians Rimon
haha obviously :P
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
